Results 1 to 2 of 2
Thread: Redface timing issue
    Jan 2013
    Midwest, USA
    Recently I pulled apart my 68 200 to replace the rear main oil seal, I got the seal on without a problem. After putting things back together I can't get the timing to come close to what it should be. I have rolled the mag back and forth and also spun the governor 180 in case it was off. Had the flywheel on the DC mark. Had a motor guy over because I have been messing with it for 3 weeks. Still can't figure it out. I am over my head. Any help would be great. Thanks guys.
    May 2008
    Orange, TX
    Re: Redface timing issue
    Did you use the correct timing mark on the crankshaft gear? There are 2 and several owners have assembled theirs using the wrong mark resulting in a no start condition.
    Front view. Correct crank gear timing mark is in the yellow circle. Incorrect one is shown by the red arrow.
    Rear view looking thru mag drive opening.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,607,005,413.57375 seconds with 12 queries
