Results 26 to 38 of 38
Thread: Just A Little Bushing..
    Jan 2006
    In A Nice Comfy Chair
    Re: Just A Little Bushing..
    I think it's for a hammer.
    The material is made for extreme beatings...
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Spread the load over surface, factor a gap filled with grease to distribute pressure evenly, and keep metal from actually touching metal, it's all good. Once that wallows out some, and the seals fail, wear will be rapid.You might see it again before retirement.
    Jan 2006
    Comes with a spare.
    ...zap!
    Do not attempt.
    Aug 2006
    MASS.
    That is impressive, as always nice work.
    Quote Originally Posted by zapster View Post
    Comes with a spare.
    ...zap!
    Problem solved.
    Dec 2009
    Stevens Point, WI
    You get all the fun jobs!
    Tube channel: https://youtube.com/@VPTfab
    Oct 2016
    countryside of NY
    Hey zap, what the bushing for? Nice work
    MM215, soon to be ex miller
    Victor torch set
    Lincoln ranger 10000 plus
  8. #33
    Jan 2008
    Richmond, Virginia
    ... The material is made for extreme beatings...
    Alloy 932 (SAE 660) bearing bronze ...
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  9. #34
    Jan 2006
    Quote Originally Posted by irish View Post
    Komatsu Hammer
    ...zap!
    Do not attempt.
  10. #35
    Mar 2017
    bar stool
    Komatsu Hammer
    ...zap!
    It'll be back soon, not as quick as it would be if it was Crapperpillar but it will be back if it's on a hammer.
    Don't forget where you put the spare.
  11. #36
    Jan 2006
    It splits the spherical bearing in no time.
    ...zap!
    Do not attempt.
  12. #37
    Hey zap, I used to single point taper thread 40 inch cast iron pipe for the acid plant where I worked.
    UNITWELD 175 AMP 3 IN1 DC
    JEFF
  13. #38
    Jan 2006
    Always a fun time...
    ...zap!
    Do not attempt.
Page generated in 1,713,279,756.48333 seconds with 20 queries
