Results 1 to 16 of 16
Thread: Looking for a funnel for filling Concrete bollards
    May 2011
    I do bollards enough to want to get a funnel for filling 4" and 6" bollards.
    I was thinking a 12x4 pvc reducer and 12x6 but not at $140 each and none second hand from eBay. Anyone have another funnel idea that isn't just making one.
    Sent from my 2PS64 using Tapatalk
    May 2011
    Re: Looking for a funnel for filling Concrete bollards
    And we are currently using old traffic cones since we can break the concrete after it hardens without damaging the cone.
    Nov 2012
    new york city
    a plastic water cooler jug with the bottom sliced off might work.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Mar 2009
    That's what the pump truck is for!!!!!! Have also used the big traffic cones.
    What about rolling up a piece of FRP with a couple of 1/4-20's and fender washers to hold it in shape you want??
    I've got a big plastic funnel for filling 8" pipe. I'll have to see if I can dig it up.
    Jun 2018
    Florida
    Put a few gallons of water in the pipe then just pour in dry concrete from the bag until all the water flows out, then just finish of the top.
    CR
    Mar 2009
    A tremie funnel is what I'm talking about. But probably cost a couple hundo.
    Oct 2016
    Delavan WI
    Quote Originally Posted by Country Metals View Post
    After reading this post the first thing that came to mind was a traffic cone but you already knew that. I would say stick with the traffic cone. Cheap.
    Jul 2018
    Cumbria, UK
    Traffic cone... you can't improve on perfection
    CT
    Go to lumber yard or local building supply, ask for a footing bell for a sonotube, don't know where you are but in the North east these are common in frost areas. Designed to be buried with the sonotube on top, makes for a footing that is wider than the sonotube, But instead of digging with a post hole digger and just dropping the tube in you have to excavate a lot more. Anyway it should make a great sonotube concrete funnel. About $20
    https://bigfootsystems.com/include/products.htmName:  form_with_bell_footing_400x300.jpg
    "Si Vis Pacem Para Bellum"
    Lincoln Idealarc 250 AC/DC
    Millermatic 251 Syncrowave 300 30A spoolgun
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
    (2) Lincoln Weldanpower 225 CV
    (4) SA200 1 short hood SA250 SAM 400
  10. Likes Pipeliner liked this post
  11. #10
    CT
    Galvanized chimney flue pipe, 6x4 reducer, put a 8x6 in that but has to be cleaned right after use.
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
  12. #11
    Stokes County, NC
    Or just serch for "cone template calculator".....
    Lance R
    1994 Lincoln Ranger 8...Kohler CH18 with 87 hours
    Smith Torch set
  13. #12
    Mar 2009
    Quote Originally Posted by kolot View Post
    Heck yeah
  14. #13
    Jan 2015
    I will have to second the traffic cone. That's how we filled all the terrorist stops at penn station. Hundred million dollar job haha
  15. #14
    May 2011
    I use old road cones. The plastic ones work best. The rubber ones move too much. Has worked out great for years
  16. Likes ronsii, kmar35 liked this post
  17. #15
    I've used cones from time to time... works ok... most of the bollards we do is bag mix but if you're using a mixer truck get... or make one of these:
    You can also buy several different designs and sizes... like this one:
    https://mpparts.com/ready-mix-concre...ch-long-mcf818
    A lot of guys make their own similar to this one... just some discharge hose and piece of tough plastic like mud flap material and some assorted hardware.
    The advantage of having a longer hose is you can fold the end over to shut it off
  18. Likes kmar35 liked this post
  19. #16
    Sep 2015
    SE Pa
    Found this on Amazon under concrete funnel Name:  0C449509-84D8-4A52-8870-AEB52236B7F2.jpg
Size:  45.0 KBName:  4330E9EE-2025-464B-BE31-C70CFCFBBD97.jpg
Page generated in 1,604,062,215.17660 seconds with 13 queries
