Results 1 to 14 of 14
Thread: Lincoln weldanpower AC DC
    Aug 2018
    Lincoln weldanpower question
    Looking to purchase a Lincoln weldanpower AC DC for a decent price. Was told the motor runs strong, looks to be in good condition, but no power to welder or outlets. Mentioned electric motor doesn't move. Not really sure what to do. Looking for any advice for what to look at before I actually make the purchase. Thanks
    May 2008
    Orange, TX
    Re: Lincoln weldanpower AC DC
    What's a "decent price"? Which specific model Weldanpower AC/DC? There were several.
    Could be anything from a poor connection, blown fuse, bad bridge rectifier to a fried stator, open winding in the rotor or a broken brush slip ring the older Weldanpower units are known for.
    If you don't know what you're looking for or at with a nonworking welder/generator, approach with extreme caution and be prepared to kiss your $$$ goodbye if it turns out to be a bust.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2011
    Bossier Parish La.
    Re: Lincoln weldanpower question
    Quote Originally Posted by msp49668 View Post
    There is NO electric motor on a Weldanpower. However, the generator portion may LOOK like an electric motor to the untrained eye. So it may be a sheared coupling between the engine and generator. If possible check to see if that portion can be turned by hand without the engine running. If it can, then the coupling IS sheared, but can be replaced. The main thing in this case is to determine that the rotor is not bound up and can turn freely.
    May 2008
    Orange, TX
    I didn't think of the "electric motor" statement in that light Bistineau. You may be onto something there.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Soda springs,Id
    If it has the tapered shaft connection it might be the through bolt got loose. Depending on how long it was run like that you might be able to retighten the bolt. Duane, given the model and spec #s you'd probably know about this.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Mar 2009
    Hmm.......electric motor parts on an engine drive. We're already in too deep on this one. Better punt.
    Mar 2015
    Milwaukee, WI
    Quote Originally Posted by Pipeliner View Post
    Backfield in motion, yeah...
    Aug 2018
    I attached pictures of the welder.
    It definitely seems like the guy has no clue about what hes talking about. All he has said is that the motor runs but it doesn't weld. He was asking $900. I got him down to $375.. I dont know much about these but I'm willing to get it and see what I can do. Seems like a good price to me...? Going to look at it Tuesday.
    I'm a decent mechanic and have worked on a lot of engines and have some experience with electrical. Any advice on what to do first or what to check for when I go will be appreciated.
    Nov 2016
    Hi Duane
    Been down that road of "Be prepared to kiss your $$$ good buy"... lost my butt on a Miller 44G 1987 series.. I had stars in my eyes...once I got it home.. it turned into a nightmare!
    Have a nice evening!
    Kell in Florida
    Everlast Powertig 200
    Everlast Supercut 51P Plasma
    Everlast PowerARC 161 STH
    Lincoln Idealarc 250 AC/DC - 1984
    "I don’t care that they stole my idea … I care that they don’t have any of their own."
    May 2008
    Orange, TX
    If salvageable $375 will be a great price. Only thing that would make it better is if it were the CV model too.
    First things to look at are the brushes and rotor slip rings. Check the slip rings for a broken one and if OK the brushes to see that they are free to move in their holders. If rings and brushes are OK, the slip rings may just need a cleaning with a fine (320grit) sandpaper.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Aug 2018
    Ok I will check it out before I buy it to make sure. Trying to find a picture of what I'm looking at. Do you have one one hand? Thanks
    Aug 2018
    I just found one. So if the slip rings or brushes are broken is it a lost cause or can they be replaced?
    May 2008
    Orange, TX
    Several W&P owners have repaired a cracked slip ring by brazing. Brushes are still available and replaceable.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Mar 2009
    I was kind of afraid of the cracked slip ring deal.
Page generated in 1,713,289,225.18040 seconds with 18 queries
