Results 1 to 18 of 18
Thread: New to TIG, Earth Ground Question
    Aug 2018
    Hey there SME's (Subject Matter Experts), I have a question about the "Ground". As an accomplished MIG'r, I know Grounding and power are is your best friend. I upgraded my Lincoln 180 to the HF brass ground clamp and I know it is a welding multiplier. Should I also use one for my Miller Maxstar 150 STL? It comes stock with the metal clamp. I appreciate any effort to answer this question.
    Bruce
    Mar 2005
    Under a Rock
    Re: New to TIG, Earth Ground Question
    a welding multiplier, Huh?
    Hmm,
    I need to get me a few of those.. HF you say?
    whats that?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Aug 2018
    Welding Multiplier, It means that it helps welding significantly. I am prior military and I always think of "Combat Multiplier".. HF is Harbor Freight...
    Mar 2005
    Under a Rock
    At ease Soldier.
    Hypertherm PM 45
    HTP 221
    CT
    I say do it. It can't hurt. I have put those brass/bronze type clamps on all my welders. Some I have purchased from Maine Oxy and some from HF. I see no difference in the quality. I also have one of these flat ones. I don't like it as much http://www.airgas.com/p/RAD64002114?...4002116:nosale
    Syncrowave 250
    Purox Metalmaster
    Aug 2018
    Louis1961,
    Thanks for the reply. Thanks for the link, I will get one. Oh and we are the same age...Me too 1961....
    Mar 2005
    Under a Rock
    I use magswitches on my Mig and stick ...... Love it!
    tig I still have the stock HTP clamp... it has copper inserts and works just fine.
    Hypertherm PM 45
    HTP 221
    May 2018
    the Netherlands
    I've never used a magnetic ground but I wonder if they could enhance arc blow with that magnetic field near the weld.
    Or do they counteract arc blow if put in the right spot.
    Eric
    Kemppi minarc 150
    Esab powercut 400
    CT
    The only reason I don't use mag switches is welding aluminum or stainless, not that I weld a lot of either, but that thought has always been in the back of my mind
    Syncrowave 250
    Purox Metalmaster
    Mar 2005
    Under a Rock
    I only tig alum or SS thats why I kept the stock clamp on that machine... mig and stick is just steel.
    ET, I have NEVER experienced arc blow ... usually the mag is far enough away from the work.
    now magnetic 45's I HAVE got arc blow... usually when I'm using the magnet to hold something small to get a tack ...
    then all hell breaks loose...
    Hypertherm PM 45
    HTP 221
    CT
    Old as dirt!!
    Syncrowave 250
    Purox Metalmaster
    CT
    Yeah, my situation is a bit different. My stick machine is my TIG machine, and I am actively looking for a spool gun for my 252.
    Syncrowave 250
    Purox Metalmaster
    Jan 2006
    In A Nice Comfy Chair
    Old as dirt!!
    Still a kid....
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Mar 2017
    Qatar
    That's how my Magswitch looks like at the bottom, I suppose from never placing it on bright shiny metal. It works well though.
    Miller Dynasty 280 DX TIGRunner
    Fronius Transsteel 2200
    Outside of Raleigh, NC
    I’ve had the stock, stamped steel ground clamps get so hot with TIG work that the spring inside lost it’s tension. Like John, I use both mag switch and the higher quality cast bronze on all of my machines. Most of the time just the cast bronze though.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Maybe you could put a small plate of steel on a clamp or wire it to the small plate with short piece of wire. Clamp on the work and attach the mag to the steel plate.
    CT
    Probably, but I am not sure I see the benefit. I like the ground clamps that I currently have. I am not sure the mag switch brings much advantage to my situation.
    Syncrowave 250
    Purox Metalmaster
    Aug 2018
    Iíve had the stock, stamped steel ground clamps get so hot with TIG work that the spring inside lost itís tension. Like John, I use both mag switch and the higher quality cast bronze on all of my machines. Most of the time just the cast bronze though.
    Yes I have one of the magnetic ones. I bought it to use in a area where I cant really get to to clean. Ok thank you, I will get the Brass one today. Thanks all for the responses..
Page generated in 1,606,666,478.69879 seconds with 12 queries
