Results 1 to 13 of 13
Thread: SA250 motor in a SA200
    Oct 2016
    I have had some time on my hands and found a 64 red face with a bad motor, and a SA250 with a bad generator. How hard would it be to combine the two into a diesel powered Red Face? I couldn’t find a good thread with the pictures still working (photo bucket isn’t sharing anymore).
    May 2008
    Orange, TX
    Re: SA250 motor in a SA200
    Pull 'em both apart and see.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Oct 2016
    I was going to buy the 64, if he comes back with a reasonable price. Then saw someone selling the 250. And my mind started to wonder. I am not sure I am ready to buy them both and experiment at the current prices they are asking. Maybe I can get some more details. With no one jumping in with an answer I am begining to think they are not just a direct bolt together
    May 2008
    Orange, TX
    Sorry. I presumed you already owned both units.
    Being diesel is the 250 an AC auxiliary power machine?
    Can you get the Code #s for both from their owners?
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2008
    Orange, TX
    I have to believe the diesel is AC auxiliary which means it operates at 1800rpm whereas the SA200 gasser runs at 1550rpm so you'd have to slow the diesel down 250rpm coupled to the red face round barrel generator. I don't see that being an issue regarding power.
    As for the generator bolting up the diesel I believe your biggest challenge will be with the starter as you will likely have to cut into the housing to provide clearance for the nose cone. This would be due to the starter being in a different location on the diesel from that of the Continental gas.
    I'm going to guess the '64 main armature will mate up with the diesel flywheel like it was made for it.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Oct 2016
    Thank you for the information
    Feb 2014
    kornfield kounty IA
    SPOOLED did this conversion and I believe he chopped the unit also. It was documented on this site a while back.
    Jul 2013
    My advice would be to sell the sa250 get you a good 200 and leave it gas . If your dead set on diesel converting it I’d go kubota if I were to do it again .
    May 2008
    Orange, TX
    Hey spooled, went to check out a couple of your threads and bummed to see all your Photochuckit pics are gone.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2013
    Yea I know , I lost them in the photobucket fiasco . I got most of them on a disk somewhere though but it would be a pain to go back through and redo them .
    Oct 2016
    Quote Originally Posted by spooled05 View Post
    Yeah, I found that thread, it sure sucked with Photo Bucket
    Oct 2016
    Okay, the 64 has a rod hanging out of the block, but I also brought home a 79 with a distributor that fails to turn, worst case it donates the engine to the 64 and I harvest a few parts for my 58 that I have.
    This makes 4 in the yard and two at my uncles, things are starting to spiral out of control.
    Nov 2013
    Bay Area Cali
    Which motor? 3 or 4 cylinder Perkins? I’ve done a 64 armature to a 4 cyl Perkins. Very strait forward.
    Long after the price is forgotten, the quality will remain.
    Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourth
    SA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Page generated in 1,713,294,374.41329 seconds with 17 queries
