Results 1 to 22 of 22
Thread: Stick lead cable care?
    Lititz, PA
    So I got my SA200 home and it had some old leads with it, one of the pair being in useable shape but with some signs of age. As I was straightening it out and coiling it back up neatly to store in my garage, I noticed some kind of black soot/grease like dust all over my gloves and getting on whatever was touching or nearby. Insulation is still very thick and holding together but tells me it wants attention. Is there something like Armor All or another conditioner I should put on it to keep it good as long as possible? I didn't measure it but this at least 60 feet I'd rather not have to buy again soon. What do you guys do?
    Jun 2014
    Southern Illinois
    Re: Stick lead cable care?
    I usually take a rag I coat with a UV protectant like Armorall and wipe the leads off as I coil them up from time to time.
    Steve
    Miller Dialarc 250 (1990)
    Miller Maxstar 140 STR (2003)
    Lincoln MP210 (2015)
    Victor and MECO torches
    I don't coil, for the same reason I don't coil garden hose or climbing rope: Because I don't feel like spending an hour untwisting and then retwisting the stuff every time I use it.
    Flake, don't coil. Same thing, only difference is that you can pull your rope/cable/hose out of the pile without twists, kinks and hockles and then put it back without having to send 200 twists down the line.
    Otherwise, 303 Protectant.
    Bilbao, Spain
    I don't have to worry about such long leads, but if I had to, I would do as I do with my climbing ropes (as Kelvin already stated). Flake them!. Or make/buy a reel of some kind.
    Lititz, PA
    Does anyone use a hand pulled golf bag cart for leads?
    Mar 2017
    bar stool
    The "Black soot" is carbon coming from natural deterioration of the rubber jacket.
    Carbon & Sulphur are added to uncured rubber in a mixing operation as blocks of gray natural rubber get mixed to be extruded onto the copper cable and then baked to cure the rubber and adhere it to the copper wire.
    When cables get old enough to begin shedding giving them a rub with Armor All or even D&L hand cleaner will keep them together a while longer. Cured rubber contains a percentage of oil.
    It's also fairly smart to hang the cable on a long radius like a chunk of car wheel. Hanging them over a spike will get the rubber to crack sooner and drop chunks off.
    Even the old school 2" pipe hanger a lot of rig guys used caused cracking of rubber cable riding down the road.
    Current generation cable insulation is more plastic than rubber.
    Sep 2005
    Cave Creek AZ
    I have 500' in 50-100' coils. I have been coiling them for 20 years and have never had the slightest issue. I just wear gloves to keep the black at bay, as well as not getting steel splinters that are attracted to the cables magnetism. I will occasionally use a rag with wd40 to wipe them down. It doesnt seem to attract dirt or leave them oily.
    Jul 2014
    Bulldog Heaven at the end of my chain
    Occasionally, I have a helper pull my leads through a rag soaked with silicone lubricant saturating the jacket. My longest leads nowadays are 115' and they well over 35 years old and are still sound. they are carried on the welder wrapped on 3/4" diameter rod and kept organized. Never have had a problem with them but the welder if not being used is inside the shop and never left outside unless I can see it.
    Lost my leads once and that isn't going to happen again.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    Nov 2012
    new york city
    Quote Originally Posted by yellowfin View Post
    never heard that one. talk about thinking outside the box?!
    i.u.o.e. # 15
    queens, ny and sunny fla
    Mar 2017
    bar stool
    Naw, too hard to come by. Plumbers all got em for their B Prestolite rigs.
    Jun 2007
    You can buy an old braider off E-bay and make new covering.
    Nov 2013
    Livingston, New Jersey, United States
    Quote Originally Posted by kbeitz View Post
    How do you make a new covering I need that done to mine
    Thanks
    John
    Sent from my QTASUN1 using Tapatalk
    Long Island
    Quote Originally Posted by Virgil5 View Post
    ...It's also fairly smart to hang the cable on a long radius like a chunk of car wheel. Hanging them over a spike will get the rubber to crack sooner and drop chunks off.
    The stress of hanging a cable over a tight radius isn't the only issue. Without ozone, the insulation doesn't mind it.
    https://en.wikipedia.org/wiki/Ozone_cracking
    Mar 2015
    Well I can say leads get hot get drug up stairs across iron through the mud and snow oil and grease crude oil salt water and they deteriate and the coating starts falling apart. If you check the inside you will probably find out that they are not in like new condition either. Wires break they get hot and cold when you cut the ends off to put new ends on you will find a lot of black dust so the inside of the rubber and the copper wire don’t last forever. I think it is great that you have time and energy to armor all your leads but lot of fine dust sticks to armor all and when you wipe it off it just wears out the outside of your leads
    Jun 2016
    Back to the jungle
    Dat reminds me of dis:
    Dec 2008
    It takes about a minute for me to coil my 100'.
    Of course I grew up roping cattle so the flip twist is automatic muscle memory for me!
    Mar 2014
    NH
    Quote Originally Posted by rexcormack View Post
    That's probably not 100' of 4/0.
    Not that I do it but figure 8s are often considered the "right" way for cord and cable, a rope bag for rope.
    Thunderbolt AC/DC
    330AB/P + Bernard cooler
    Syncrowave 250
    Oxy/Ace torch
    Dayton 160 MIG
    6CF pot with 185 compressor
    Too much big equipment
    Even more small tools
    Jul 2014
    My long leads are 1/0 and when they are stretched out fully I usually grab them about the 1/2 way point and drag them into two lengths to recoil onto their holders. Too heavy to drag standing at the machine and pulling towards you dragging the full length along the ground.
    Of course if I were a "real man" I'd just coil them up at my feet and throw one coil over each shoulder.
    Slob
    Mar 2017
    bar stool
    No need for concern over your age induced loss of manhood Slob.
    Once yer granddaughter gets that skid up & running she'll teach you how to throw a Prussick loop onto the cable and haul it in with the boom.
    If only you hadn't attacked PeeAir and pissed Irma off you might have been able to get parts to make up a capstain to pull them in.
    Jul 2014
    Capstan winches I have quite a few of but the smallest is 20K line pull so a bit heavy in it's own right. You done got me to thinking though. I'll bet I could modify that contraption Irma uses to walk that useless SOB into a harness I could attach a rope to and tie off the other end to a load I needed pulled. Then just show ole "PEEAIR" a 400A ground clamp and get the load moved effortlessly on my part.
    Slob
Page generated in 1,607,047,774.55636 seconds with 12 queries
