Results 1 to 25 of 26
Thread: 1/16" stick rods
    Jun 2018
    Eastern Pa
    1/16" stick rods
    So I was just messing around with these hobart 1/16" 6011's to see if they might be able to substitute a mig welder in certain places/circumstances. I tried running them on first gear and 0-5 on my sa200. that was an epic fail. way too cold. so I turned it up a bit and they seem to run nice around 15-25 on the fine control. the problem is I seem to burn through everything I tried welding with them (14 or 16 gauge tool box I believe). Anyone else try using these in a real life application? like what would you even be welding with them and how thin of a material? would 1/16 inch 6011 or 7018 be good for making an xray quality groove weld on 1/8" plate? would 3/32" 7018s be too big for that if you didn't have a backer and copper bar or tube clamped down somewhere?
    Jun 2018
    Knoxville TN
    Re: 1/16" stick rods
    6011s are meant to dig into the metal, therefore not really suited for thin metal. More for rusty or unclean metal. I think you can use them for brazing rods, not real sure I don't use the 1/16" 6011s, only 3/32" and 1/8". For the thinnest metal you can possible weld with stick you need 1/16" 6013. Even thinner run it on DCEN. I've used these on sheet metal, but not sure exactly what gauge it was.
    Dec 2015
    For thin plate, try 5/64 7014, DCEN. Welds like using 3/32 but runs at a much lower amperage. Makes a clean smooth bead with excellent penetration.
    Laredo, Tx
    I've tried those 1/16" E6011s, but they didn't run like 6011's at all. Ran just like 6013s. Did not "dig" at all, just a nice smooth bead with 6013-like slag covering. Same machine that I had used to run 3/32 & 1/8" 6011s previously. No arc force controls so it wasn't that either. Might have just been my luck though.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    May 2007
    Quote Originally Posted by Scrapman Industries View Post
    c'mon, jack, get real w/ the times. appreciate ur humor, as u seem 2 no the talk. maybe in another night i cud get in the mode, but its only a thurs
    Dec 2015
    Western New York State, USA
    welding 14-16ga general rules
    1) tack weld often
    2) aim for zero gap in joint
    3) weld inch or 2 and stop to let cool off and if needed beat joint tight no gap
    4) welding fast vertical down often used
    actually 14ga most use 3/32 rod. usually people have trouble cause they dont know how to do sheet metal welding. yes sheet metal welding requires skill and patience.
    Jun 2016
    Back to the jungle
    Quote Originally Posted by dee_veloper View Post
    for thin plate, try 5/64 7014, dcen. Welds like using 3/32 but runs at a much lower amperage. Makes a clean smooth bead with excellent penetration.
    bingo
    Dec 2015
    many use 6011 cause it is a quick freeze rod. either whip or just break arc and let cool as needed. most know better to weld a short distance and stop and let part cool off
    filling a gap out of position like overhead welding of sheetmetal can be difficult. best not to have a joint gap with thin metal
    6011 usually can weld vertical down which is often easier than vertical up with thin metal
    Sebeka and Bemidji MN
    I've done a little thin work with 3/32" 6011.
    Worked really good as overlapping tack-tack-tack.
    Cleaned with grinder, then vertical down to tie together.
    For flat work, overlapping tack-tack-tack and done.
    I don't really care for 1/16" rods.
    Mig would have been better, but I was in a field with the Bobcat 225n.
    Airco 300 - Syncro 350
    CT
    Jody covered this in one of his old videos. Polarity is going to be key (DCEN not DCEP). He welds some steel that is 44 thousandths thick (19 gauge-ish?) as well as some 70 thousandths exhaust tubing. Jump ahead to 6:12 in the video for 6013 and 12:45 for 6011
    Syncrowave 250
    Purox Metalmaster
    May 2010
    ct.
    1/16 6013 is good for the guy with only a buzz box. No mig/tig .
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    May 2010
    ct.
    Mar 2013
    I've used 1/16" 7018 on a lot of 16ga square tubing. It's not too bad but you have to be fast.
    Used 5/64" 7014 and 6013 rods on 16ga as well.
    DCEN or DCEP didn't make much difference in my opinion.
    Problem comes when you blow a hole somewhere and have to repair it. Having a piece of tigrod or something can be helpful if you add it while welding. It will cool down the puddle. Can also be used if you have gaps.
    Outside corner download, like was done in the video above, is the absolutely easiest to do cause the heat will spread out and the puddle is traveling towards cold steel and not hot, like uphill.
    If you don't have a mig at hand, 1/16" will help you do 16ga and in some cases even thinner. I guess that is why it exists.
    Jun 2007
    Fast is when you try the aluminum arc rods.
    Quote Originally Posted by kbeitz View Post
    You ain't a kidding there I think I went through three packs of that stuff before I got a halfway decent(holding) weld... and it still looked like I found it in a pigeon house.
    Jan 2005
    Don, DDA-52 put me onto the EN welding 3/32 6011 sheet metal 20 ga. Can use 1/8 just as well. Turns out with zero distortion,and works with dingbat machines to.Although we where using my C-300 Powerwave, and Kevin's dynasty 350 just for fun. Thermal-arc 95s works just about as well..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
    I use 3/32 6011 and 7018 frequently on 14g and 16g. Joint confuguration is important. 16g to 16g tee is easy to weld with 3/32. I am usually not butt welding. 16 to 16 butt is difficult with 3/32.
    Jun 2018
    Eastern Pa
    Thank you to the guy who posted that video. I totally see what I was doing wrong with my 6013 and why I absolutely hate it. Apparently I've been running way too cold for that rod. I also see what I was doing wrong with the tiny rods. Apparently my tool box is more like 20 gauge and I was trying to whip it. as soon as I got the metal to stick to my trailer and the tool box it just blew through the box. gonna mess around with them some more when I get the time. I know mig is more useful and more practical, but I like stick welding better and want to get as skilled as I can with it. Plus the big lincoln is already on a trailer. if I gotta use mig when I'm on a job I gotta drag out the genny and hope my back don't blow out trying to get the 400lbs beast onto my truck. If its just a simple farm weld I'd rather just hook up the stinger and turn a knob down.
    Jun 2018
    Eastern Pa
    hey man You laugh but I'm serious. I was out there in the rain trying to weld a toolbox onto my homemade welding rig. I ended up having to bolt and rivet it on but I'm like determined to learn these tiny rods. I was out there today welding 1/8" grooves with 3/32 6011 and 7018 cutting em up and pounding em with a vice and sledge hammer to see how they hold up. the 6011 cracked bad, but the 7018 is like unbreakable. I think I was whipping too much with the 6011 though. gonna try again sometime. I think my 7018 samples would pass xray. I had to use an aluminum backer as a heat sink though.
    Ct
    Yeah I keep some of those on the truck for aluminum repairs that pop up, but man it's hard to see through all the slag
    For years before I had a decent welder for feild work I used the harbor freight "90" amp stick welder with their 1/16th 7014 rods, I was welding mostly fencing and railings together, it worked well. Now I keep some 1/16th 6011 on the truck in case I have to weld super thin wall pipe or something
    Jun 2018
    Eastern Pa
    Thanks man. that was what I was looking for. theres alot of railing work around here.
    Apr 2010
    Scrapman Industries
    1/16" anything requires a superior hand - small is not easier - small is more
    difficult . . .
    It is: hard to see, hard to maintain arc gap/distance, and often melts at the
    stinger - because, only really expensive machines have discrete adjustment.
    Tech Tip: Cut 1/4+- off the top of the rod - beat/strip flux from the top for
    a solid contact in the stinger.
    A good portion of set-ups, I stick the entire rod straight out the top of the
    stinger, and bend-down a little over 90°.
    This allows you to rotate your wrist, and maintain proper 'rod touch' angle
    welding something irregular/cylindrical . . .
    Hope this helps . . .
    Opus
    Jun 2011
    Texas
    I remember welding a wrought iron fence - some 1600 welds attaching 1/2" square tubing to 1" square cross supports. I tried it with 1/16 6011 and 7018, and they were so wiggly and bouncy, it was hopeless. I ended up just using NR-211. Worked fine.
    So just what kind of welding is 1/16" 6011 good for?
    -Ruark
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
    Laredo, Tx
    Quote Originally Posted by Ruark View Post
    Well then that is the answer. A stinger accessory that supports the rod end so it doesn't wiggle, and "folds up" back to the stinger with some hand pressure as you're welding away!
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Jan 2017
    I’ve actually had good luck running 1/16 6011 on DCEN. I know- they’re not designed to run that polarity. But it does allow you to run a little more amperage and prevents blow through.... as long as you don’t dwell to long.
    Continuous beads are probably out of the question unless you ‘back-step’ or something similar.
    Yes this my first post- long time lurker.
    Rob
Page generated in 1,611,627,388.16528 seconds with 11 queries
