Results 1 to 25 of 32
Thread: 140 amp mig question
    Jun 2018
    Eastern Pa
    So I was looking into the Hobart handler 210 mvp for portability reasons vs my lincoln 180hd. alot of the stuff I currently seem to be welding is 1/8" plate which I can weld just fine now with stick or flux core. It would just save alot of time and effort if I could just throw a little 110v machine in my truck and use the customers power or have a machine small enough that I could just plug it in and not have to fire up my generator every time I need to weld. Right now currently I need to take my generator every where when I weld something so that I know I'll have 230v and that does become a hassle. so to have a dedicated mig welder thats also portable I was looking into the 210 mvp from hobart. I was just wondering if it could weld 1/8" plate off the 110 side with a max amp output being 140. I've never welded with a 110v machine before so I don't really know. I also couldn't find anything on the internet on running this machine off 110v. Anyone try this with theirs? I've also never had my lincoln set up for mig. Its more like a dedicated flux core machine with all the outside welding I've done so welding with mig on a machine thats not bolted down to a factory floor would also be a first for me.
    Oct 2013
    Long Island, NY
    Re: 140 amp mig question
    I used to own a Hobart 130 and then a 210.
    The 130 welded 1/8” just fine. The duty cycle was **** and I can’t say I welded a skyscraper with it but for general non critical projects it was fine. The 210 has a much better duty cycle i never exceeded it on 1/8” material
    Something to consider with relying on a 110 machine and tbe customers power supply, in residential spaces and some
    Commercial you’re gonna be dealing with 15amp outlets when you really need a dedicated 20 amp minimum. You’ll also need a good quality heavy gauge extension cord as well.
    You can run the machine off of a 15amp supply for a very short time before you trip the breaker. If you’re any good distance from the outlet you’re gonna lose a lot of juice too especially if you don’t have a thick enough cord.
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
    NW New Jersey
    I think the lincoln 210MP is a little bit more portable, at half the weight. I costs a little bit more but you get stick capability too. I've used the lincoln around my factory, frequently using 115v 15a lines, and it has worked well. Good for small stuff like conveyors, and rails, and machine guards etc. I haven't used the Hobart, but people say its a good machine too. Using 115v lines to weld is always a crap shoot, you never really know how much you can get from a circuit until you use it. Buy or make a good quality cord, try to find a plug close to the electrical panel. My old electrician would often put a heavy duty(20a) quad outlet right on the side of the panel when when he installed them or did work. That way he had a place to plug in his equipment (puller, bender, bandsaw, etc.), other people may do the same thing. I wonder how the Hobart compares to the Lincoln in current draw at 115v.
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Laredo, Tx
    The increase in welding capability by using the 230-240V as opposed to 110-120V is more than worth the hassle of taking a generator, IMO. At this point if you're doing that much mobile work, why not just leave the generator on the trailer/truck, or just get an engine drive welder with a suitcase wire feeder?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    SoCal-LA
    Don't know how much they cost, but cool!
    MillerDynasty700DX,Dynasty350DX3ea,Dynasty200DX,Li ncolnSW2002ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig4ea,MigMax1ea.
    Oct 2013
    Long Island, NY
    350 amps
    Zach
    Lincoln 210mp
    Lincoln SW200
    Laredo, Tx
    That should deplete the battery real fast, lol. Notice how they dont' say how long it lasts, lol. I wonder if they do away with a DC-AC inverter since the output itself is DC, to cut the losses of power conversion? If it converts to AC, it must be one heck of an AC inverter! But I do admit, it's a nice implementation of a simple "battery pack" to mobilize a device. But I'm going to wait for the Wi-Fi 4G model with LCD screen so I can check WeldingWeb posts.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Oct 2013
    Long Island, NY
    It says it can make 500 inches of weld on 1/4” material on a battery
    Zach
    Lincoln 210mp
    Lincoln SW200
    Laredo, Tx
    on the settings for 1/16" material, or settings for 1/4" material?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Oct 2013
    Long Island, NY
    Good question...
    Guy in the video made a pretty lame looking bead too. I know it’s thin flux core but if i was doing a promo video is probably hire a guy to lay a beautiful weld.
    Zach
    Lincoln 210mp
    Lincoln SW200
    Los Angeles
    Pick up the HF Migmax 215, try it out on 120v.
    If it doesn't do what you need just return it.
    1 year hassle free return.
    I know the Miller 210 will do 1/8" as my Passport Plus will do 1/8" on 120v input power. They're both inverter machines and utilize the input power way more efficiently than transformer machines.
    The Paasport will run 1/8" Aluminum like butter too on 120v.
    MM211 (Sold)
    Miller 125c Plasma 120v
    Jun 2016
    Back to the jungle
    A 110/120V machine wont do shiit unless you get real serious with beveling and multi pass------with 030 and CO2.
    Dont get me wrong. I've done a ton of work with a lincoln 140 and a dual volt 180 stick on 110 on ornamental. No complaints. Just facts.
    Nov 2012
    new york city
    let's see that machine weld a pile point or bucket shank.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Jun 2018
    Eastern Pa
    Yeah I got a SA200 on a trailer at the moment. I used to have my 6.8kw generator mounted on a truck bed trailer. but some times for simple jobs it seems like it would be easier to just throw a welder and grinder in the truck as opposed to loading up all my gear or hooking up the trailer. Eventually Id like to have an old PennDOT dually with the Sa200 and generator mounted on it so I'm not wasting time loading and unloading all my stuff but for right now I'm just using my tacoma. Which also doubles as my scrap hauler and gets used for everything else I do. Just had a thought on the 210mvp when I was working on this guys truck.
    SoCal-LA
    Good question...
    I saw that too. Perhaps that was done to farm code.
    May 2010
    Port Orchard, WA.
    Guy in the video made a pretty lame looking bead too. I know itís thin flux core but if i was doing a promo video is probably hire a guy to lay a beautiful weld.
    Yeah, but self shielded flux core wire sucks!
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jun 2018
    Eastern Pa
    I kinda like self shielded flux core. but probably cause thats all I had for awhile. That was a good weld by the way. is that what you ran off your suitcase plugged into the SA?
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by Scrapman Industries View Post
    I was kidding about the wire. Iíve run tons of self shielded flux core wire.
    Here is the machine I used to make that weld.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Feb 2014
    n.w. of chicago
    China freight has a new green machine 140 under 400.00 I don't know anything about but they have a good return policy if it's a turd, .030 flux core and a 130 amp machines have a place and are holding a lot of stuff together, I'm guilty of welding with one when to lazy to do with a bigger rig as long as you prep the metal/joint and use common sense with lower amp machines, I also like flux core,
    Jun 2017
    AJO, ARIZONA
    Looks like a completely affordable $4950.00, mere pocket change for an avid hobbyist. It is a cool machine though.
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    ďFreedom is never more than one generation away from extinction.
    We didnít pass it to our children in the bloodstream".
    RONALD REAGAN
    Jun 2017
    AJO, ARIZONA
    Quote Originally Posted by pat h View Post
    I've looked at the green HF welders, the wire feed looks to be decent, it looks like it's all metal.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    Feb 2014
    n.w. of chicago
    And they weigh about 20's if I was looking for a occasional use portable machine I would at least try one they might suprise you who knows, ya got 90 days I think to try them, they also make a couple duel voltage jobs
    Aug 2008
    Toronto ,Canada
    I would consider having a couple of welder plug to dryer outlet adaptors handy .
    Ken from ontario,Canada.
    Guy could buy a nice engine drive for what they cost http://www.cegroup.com/182277,AIM_35...eavy_Duty.html
    Laredo, Tx
    I agree. But I'd still rather have a beefy generator for that price. You can get a Winco 22/19kw genny for $4500, which should be able to power anything that consumes less than 80A on 1-Φ 240V operation.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
Page generated in 1,611,181,821.24844 seconds with 12 queries
