Results 1 to 4 of 4
Thread: TIG NooB w/ squarewave 275 Troubleshoot
    Jan 2019
    Hello, I aM cURTIS. I hve been an automotive tech for 10 plus years. I recently got commercial Diver certification and underwater welding. I decided to purchase a TIG/Stick welder to build up my skill while at home and not offshore.
    SO,
    I recently got my hands on a Lincoln Squarewave 275. code#10605
    When turn machine on I get buzz noise and that's it.
    Voltmeter and Ammeter both have no display functionality.
    I tested the T1 transformer(GOOD)
    tested inputs to PC Control Board(GOOD)
    I can see an ARC on the connections inside the polarity switch when change setting from AC to DC
    Guy I purchased from said the Control board was bad.
    But after extensive visual inspection I find nothing that would lead me to believe it is faulty.
    (I have a lot of circuit board inspection and repair experience)
    Name:  20190116_024736 - Copy.jpg
    Name:  20190116_024750 - Copy.jpg
    Name:  20190116_024819 - Copy.jpg
    Name:  20190116_024809 - Copy.jpg
    Sebeka and Bemidji MN
    Re: TIG NooB w/ squarewave 275 Troubleshoot
    I'm not real familiar with the modern method of rectification, but on a transformer machine I would suspect a failed diode.
    The arc when changing the selector makes me think your problem is similar.
    Clamp your meter on a hot leg and see how much input current is being used. If more than just the idle current amount, I'd test the diodes or bridge rectifier, which ever you have.
    Airco 300 - Syncro 350
    Jan 2011
    Hutchinson Kansas
    I have one of those. When you turn it on it does just what you say. When you strike the arc the fan will come on.
    I wonder if its just the display that quit. Flip the process switch down to stick set the amp dial to 11 o'clock position (about 100A) see if it will burn rods.
    Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
    Jun 2017
    AJO, ARIZONA
    Welcome!
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    RONALD REAGAN
Page generated in 1,606,200,888.57409 seconds with 12 queries
