Page 3 of 7 FirstFirst 12345 ... LastLast
Results 51 to 75 of 169
Thread: Splitting maul build
  1. #51
    Re: Splitting maul build
    I always thought splitting wood accomplished several things.... one of which is helping the wood shed moisture quicker so you don't have to put it up for 10-20 years before it is seasoned enough to burn good....
  2. #52
    Long Island
    It does, but you need to season it to begin with to be more easily splittable. If you're splitting green wood by hand, you're working too hard.
  3. #53
    city of Four Flags
    I liked burning wood,
    https://www.tractorsupply.com/tsc/pr...-pellets-40-lb.
    That maul is looking like you are going to need a chain fall to lift it but once you drop it it ought to split the entire tree in one shot.
  4. #54
    Nov 2014
    PDX PNW
Size:  107.8 KBgona bevel the point area a little deeper and flatten the point and fill it in with weld. I think 3/8” or so will be good enough build up for now
  5. #55
    Quote Originally Posted by rlitman View Post
    You're right....I learned at least 30 years ago that when the wedge goes in and water comes out then it ain't seasoned enough
  6. #56
    Hey Moto, How abouts a lot more bevel then fill it with silicon bronze??? ought to look cool!!!
  7. #57
    You can always tell one of them high fallutin' hoity toity TIG types...…………………………….They use a flap wheel to bevel with
  8. #58
    Nov 2014
    PDX PNW
    Going with 70s2 ronsii and possibly 312 on the tip. I’d think about letting you weld it out Sam but it might could out little ugly
  9. #59
    Stick like Tig Name:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
    Name:  concrete mixer129-1.jpg
    Name:  concrete mixer130-1.jpg
  10. #60
    Gotta git
  11. #61
    Nov 2014
    PDX PNW
    Looks like you pass with a A-
  12. #62
    Dec 2009
    Stevens Point, WI
    I miger.
    Tube channel: https://youtube.com/@VPTfab
  13. #63
    Nov 2014
    PDX PNW
    Here’s what tig looks like, 5 cup cut 3/32 70s2Name:  AF867B94-BE72-4F04-A374-970DBDFAB31E.jpg
Size:  86.8 KBName:  62401C8D-BAD9-4D6C-B6DC-5F5300CE5A82.jpg
Size:  112.9 KBName:  95A82D44-0A3B-4139-9E1F-748DDE5E99CA.jpg
Size:  127.3 KBName:  CAB0BFAF-7B8E-4868-A417-5164CEA2DEAF.jpg
Size:  118.7 KBsome more pics coming soon
  14. #64
    Nov 2014
    PDX PNW
    I put another fillet weld on each inside joint and got everything beside the tip. Put my 1/8” tungsten in and used 230 amps at timesName:  B6635DE3-51F3-4269-B822-2EBAA95D7A74.jpg
Size:  106.6 KBName:  4DB8766C-7797-402C-8F11-20DD3CF7BCCD.jpg
Size:  98.8 KBName:  4A521C8E-BE6F-4D39-A406-A182A5BA36E0.jpg
  15. #65
    Looking very nice
    Have you figured a handle mount yet?
    Also: you should think up a signature/brand you can weld onto your works
  16. #66
    Nov 2014
    PDX PNW
    Thanks ronsii! No I haven’t. Figured I’d date it tho lol. Looks like I could have grooved out the nose a little more but whatever it’s got 3 passes under it everywhere. Here’s my idea for the handle. Think I’d make much difference whether i put it on the inside or outside?Name:  F3966544-378D-4DE5-AF8D-6E34B4908AC7.jpg
Size:  102.3 KBName:  5FA93260-7EB1-4D8F-8BE9-D0E95DCD0739.jpg
Size:  107.9 KBoutside would be much easier and easier to put some screws or pins in to hold the shaft in
  17. #67
    Outside and you won't be able to 'sledge' it into the wood if it gets stuck...
  18. #68
    Nov 2014
    PDX PNW
    I could make it outa 1/4” wall. I’m not sure I’d have a problem getting this puppy stuck much. If it does it will have a 2”x3” handle at the head. Maybe I could leave an inch and not have the handle go all the way up the back, also it’s got plenty of room on the sides of the back Incase it did need hit
  19. #69
    Feb 2010
    Bandera,TX / MN
    Moto I built one using 4" CRS for the head and conduit for the handle.
  20. #70
    If the handle is outside the triangle, it will be impossible to control it as you raise it over your head. It will want to roll off to one side of the other, depending on gravity. The effect is at its worst when you reach the high point on the arc of your swing. Think of a pendulum.
    Any deviation from a true circle swing will cause the heavy part to want to seek gravity, and fall off towards that perpendicular point. In other words...…..it will twist in your hand to one side or the other. Don't want something that heavy twisting in your hands.
    For S&G's.....tack a piece of stock outside, and see how the head will always want to "hang", instead of just sit there in a balanced mode. You want balance. Balance is beautifulName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
  21. #71
    Jun 2016
    Back to the jungle
    Gimme a 10 lb rapper and 15 minutes and I'll fill a 12 foot trailer with red oak read for the stove( 12-16" Diameter dried)
  22. #72
    Jan 2016
    northeast USA
    I was told you get warm 3 times by using wood for heat..once when you cut the tree down, second when you split it and third when you burn it....that maul is more like a heart attack for the second warming..
    lets see how much swinging it takes before it becomes too heavy to lift or you blow out a shoulder or arm doing it...
  23. #73
    Oct 2012
    Hood River, OR
    I have a wedge like bonzoo posted (black, not gold). If one or two swings with a regular splitting maul doesn’t get the job done or if it looks knarly I grab the wedge. Works great for me. I also try to save up 8-10 cords worth of wood to split every few years and rent or borrow a hydraulic splitter. In between I cut and split miscellaneous stuff that has to come down anyway.
    Looking forward to a video with the monster maul.
  24. #74
    Big Lake/Monticello MN
    I was always told the same.
    When younger I used my 20 lb maul almost exclusively.
    As I got older I looked at it as the one to use when a 6 or 8 didn't work because often the light ones worked in one or two hits on straight stuff.
    So now it only gets used when needed.
    I never found it real tiring to use, just unnecessarily heavy to carry around - which made me more tired.
    It really drives a wedge nicely
    Syncro 350
  25. #75
    We need a progress report, and an address to send the 'get well' cards to
Page generated in 1,713,255,146.89880 seconds with 18 queries
