Results 1 to 16 of 16
Thread: Lincoln Power Mig 300 part# L11346-1
    May 2018
    Lincoln power mig 300 part# L11346-1
    Hello
    I have a Lincoln power mig 300 and it has a burnt out P.C. board that is discontinued. Itís part# is L11346-1. Iíve searched everywhere for it and no luck. Thought maybe someone on here might know a source to get one. Any help is much appreciated.
    Dec 2014
    Wasilla, Alaska
    Re: Lincoln Power Mig 300 part# L11346-1
    Google "printed circuit board repair" , I have heard of a place called Flight Systems, but, have no personal experience with them. Good Luck!
    Mar 2019
    I have power mig 300 with a totally fried chopper board - the one with the 5 big capacitors (red or blue) on top. Maybe we can make one good one out of these 2?
    Ceres, California
    Spool gun control pcb. Unplug it and the welder should work for everything but spoolgun use. Unless the feed head pcb has failed also. How do you know the spool gun pcb has failed? Have you connected a laptop and run diagnostics?
    Go to powerwavesoftware.com and down load the powerwave manager. This will allow you to peak inside.
    Also you can take a snap shot and send it to lincoln.
    USA
    ccawgc That's amazing you can do that with those machines!
    looking for an old cheap Engine drive
    Ceres, California
    spoolgun pcb is a small pcb that plugs into the wire feed control pcb (feed head pcb) we call it a daughter pcb.
    Control pcb may complain that it is missing. just do a factory reset and that should clear.
    May 2018
    I took it to a shop. And they said itís burnt out was smoking. When I turn it on it want go past the start up procedure. It throws a code and thatís as far as it goes.
    May 2018
    What board is L11346-1. I donít know which board to unplug. Throwing code 214
    May 2018
    I unplugged the 10 pin plug and it doesnít throw the code 214. It goes through start up and all seems fine. Is this the correct plug to unplug? Seems to weld fine and the board doesnít smoke anymore. Is this the correct? Thanks for the help
    Dec 2014
    Wasilla, Alaska
    Let me say this, I am not Nikola Tesla, but, by the process of elimination I think you have isolated the source of the machine throwing the code. "ccaw" or "Duane" will probably check in on this, both are knowledgeable and very good at helping, Good luck.
    Ceres, California
    error 214 . control pcb could not find the wire drive pcb.
    A short is the spool gun pcb may have caused the feed head pcb to shut down and stop talking.
    Post the code number of the welder and some of the wire numbers in the 10 pin plug.
    Checking the manual I find two different versions of this welder. One version the spool gun pcb plugs directly into the feed head pcb and the other it sets to the side in the bottom and is connected by wiring harness.
    The spool gun plug and the remote foot control plug go through this pcb. depending on which machine you have the 40vdc needed to run the drive motor could go through the spool gun pcb first.
    May 2018
    I have the second one. The board is on the bottom. I can see where it is fried. If unplug everything from that board it still throws the code 214. If I just unplug the 10 pin connector. It doesnít. And it welds fine. And doesnít smoke no more. I welded for like 10 minutes straight no problems.
    May 2018
    Do you care to sell the board if it the one I need.
    May 2018
    Quote Originally Posted by oldphardt View Post
    Do you care to sell the parts I need if they are correct?
    Apr 2019
    Hghtime, Would you be interested in seeing if the board could be repaired? If so, perhaps you could attach pics of the component side and solder side of the board and I could take a look.
    - - John
    May 2018
    Quote Originally Posted by Tron View Post
    - - John
    The board is a potted board. I was told itís not repairable.
    Brian
Page generated in 1,607,081,630.28470 seconds with 11 queries
