Results 1 to 4 of 4
Thread: Power Mig 300 Help
    Mar 2019
    Power Mig 300 Help
    Hello, I recently acquired a Lincoln power mig 300. The machine had been setting in someone’s garage for about 8 years. When I brought it to my shop the first thing I did was check to make sure it was wired for 230 volts, which it was. I turned the machine on and the display came on and all seemed well. But when I tried to feed wire through the feeder I noticed that the feeder was not turning. I checked all the connections and everything appears fine. I just get a loud clicking at the back of the machine when I squeeze the trigger. If I hold the trigger down after about 5 seconds the fan comes on. Any help would be greatly appreciated.
    Jul 2013
    North Carolina
    Re: Power Mig 300 Help
    Can you make the drive rolls turn at all? I think that machine has a stick mode capability. https://www.lincolnelectric.com/asse...oln3/im736.pdf
    Lincoln Electric:
    Ranger GXT 250
    SA-200
    LN-25
    Pro MiG 256
    Pro Mig 180
    Esab CV 251
    Invertec 160
    Victor Torches”
    Mar 2019
    I have a power mig 300 with a totally fried and burned chopper board - the one with the 5 big capacitors (red or blue) on top. Guess I will part mine out as Lincoln wants more for 16 year old board than a new welder and 3X the current value of the machine.
    D
    Dec 2014
    Wasilla, Alaska
    oldphardt, have you contacted any of the printed circuit board (PCB) repair places? May be less expensive than Lincoln. Good luck!
Page generated in 1,607,025,054.46669 seconds with 11 queries
