Results 1 to 11 of 11
Thread: Box blade repair
    May 2017
    Box blade repair
    This is a box blade that I repaired. It took awhile and I used a lot of advice on this forum and I appreciate everyone who helped me.
    The original box blade when I got it is shown below.Name:  IMG_2527 (1).jpg
    It is a 6 foot box blade but it had a funky set of parallel plates with spacers that held pins for the teeth and there were only 4 teeth.
    As you can see, the welds were poor and were coming apart.
    I decided to make this a welding project with my son.
    I thought about rewelding the spacers but I thought the design was bad so I cut the plates off. I was going to cut pairs of holes for the teeth in a square tubing, but someone told me to make it even better by welding a plate on top and cutting a hole in it and use angle iron for the pins to stabilize the teeth. So that is what I did. some of the threads related to this was cutting 1 inch steel with a torch, plasma cutter or bandsaw and extension cord or leads.
    The finished project is shown below. The nice welds like seen in the close up was done by my son. The bad looking welds were done by me, but I did get a little better.
Size:  53.1 KBAttachment 1699544
    The top plates were 1 inch thick steel with a hole cut out for the teeth. It was welded to 4 x 4 x 3/8 inch thick square tubing. below the 1 inch plate are pairs of 3/8 inch thick angle iron 3x4 inches. 3 x3 inches would have been better. The square tubing was welded to the 1/4 inch plate on the ends and the angle iron above it. All welds were done with a root pass of 1/8 inch 6011 and two capped with 1/8 inch 7018. More info in the next post.
    May 2017
    Re: Box blade repair
    Per recommendations I bought this band saw and it worked great. I cut the 1 inch plate with a torch but cut the angle iron with the bandsaw.
    I bought a 50 foot extension cord and that sure made welding easier on a 600 pound box blade. I was able to take the top attachments off and flip it so that all welds were flat.
    All welds were done with this $149 welder:
    My son complained a lot about it when running 6011. Without hot start it was hard to get the arc started and the voltage output varied a lot. We had to run the 6011 at 110 amps to get it to penetrate. 7018 ran OK.
    This box blade is overkill on the metal and the welds and design, but it was fun. And the box blade went from close to useless to a mega box blade. I have extended the blades to max depth and hit tree roots and all welds have held just fine. Unfortunately I angled it forward, lifted it up and one of the teeth caught my tire and poked a huge gash in my tire. Tractor tires are expensive.
    My next project is going to be a ROPS (rollover protection structure) for the tractor. I think I will upgrade to a Hobart 210 stickmate. It is supposed to be equivalent to a Miller Thunderbolt but less expensive.
    Nice job The fresh paint really makes it pop!!!
    Looks like it's ready for some good hard work.
    Northern Cal., Shasta County
    Yeh if that 4x4 box doesn't hold up I dunno what will. . Looks great.
    May 2017
    Pitman PA
    You say its overkill, I say you made it stout enough so it stays together for what you are going to do with it for a long time. Some of these operators tell me I overdesign overweld and overkill everything I work on. Some of these shovel operators are the ultimate welding test, if it can be broke they will find a way to break it. I know for a fact some will deliberately try to smash and break what we just got done fixing, just because they are who they are.
    You done a good job there...don't fret about overkill its a good stout blade that will give many years of good service
    Feb 2010
    TX / MN
    How many times has someone said I wish I'd done it cheaper? Fix it once right and be done with it.
    Jan 2016
    northeast USA
    great looking repair and upgrade, the original looks like a bad design that was weak....
    May 2017
    The idea for the design came from killdozerd11. Thanks killdozer.
    Sep 2012
    Utopia,TX / Pasadena, TX
    Quote Originally Posted by jeffrey.penfield View Post
    Yep, know about them tires. New tire cost me $400, job paid $300. Cost of doing business. One of the stabilizer bars came loose and let the ripper slash the tire.
    May 2017
    Quote Originally Posted by In Utopia View Post
    In my case, I angled the box blade backwards with the top link so I could smooth out what I just dig up with the teeth fully extended. My mistake was not raising the teeth or removing them. I had lifted the box blade up and was moving to another location. The tooth being extended and angled forward caught my tire and kept me from moving but I did not know what the problem was. I thought I was having trouble getting over a stump. So I revved it up to get a running start. I saw a lot of water bubbling up under pressure and I thought I hit a water line, but it was only water in the tire. It was plain water without antifreeze or Calcium. I bent the pin holding the tooth but all my welds held. After freeing the tooth I must have got mad and thrown it and now I can’t find it anywhere.
    Don't feel too bad.
    I was running the brush hog on the Olly 1850. Just toolin' along, happy with the world.
    Well, that old gal is a row crop tractor, and it has real nice ladders that go down from the cab. Makes it easy to get on, and off the machine.
    Now, why does it matter that it's row crop tractor, with a row crop set of ladders??????????????????????
    Those ladders extend down to about 24ish inches offa the ground. Ok for flat groomed fields.
    But...………..I always fight Cedar trees, and if they're about up to maybe 5 feet tall...……….I just run 'em over with the brush hog. I DO USUALLY BACK OVER THEM WHEN THEY'RE THIS TALL But sometimes I get in a hurry
    So, like I said...…….cruisin' along, lookin' at the birds, whistling a nice toooooon, and enjoyin' a smoke.
    I see one in front of me that's a skosh over 4 feet tall...…………….maybe 4'10"...……………………..
    Too nice a day, and things goin' too good,, for all that backin' up crap...……….so I just motor on
    Tractor smashed the tree nicely, and the brush hog tore it to bits as it passed over it...……………
    BUT THE LADDER CAUGHT THE TREE AS I RAN OVER IT...………..BENT REARWARD...…….SHEARED THE SIDE BRACKETS OFF THE STEP...…….AND PUT A GIGANTIMO HOLE IN THE TIRE
    About a $500 wake up call Name:  itsok.gif
    And...………..I still haven't fixed that ladder, and it's been maybe 15yrs Looks like a dagger pointed straight at the tire
Page generated in 1,607,045,810.04719 seconds with 12 queries
