Results 1 to 4 of 4
Thread: Dual shield settings
    I should take a picture of the chart in my Millermatic 252. Where they give recommended settings for dual shield they are markedly different from those I see in demonstrations.
    Typically, internet demos are using 1.5 to 2 volts higher, and wire speeds 100 or more IPM slower than recommended in my welder. Have I missed something?
    When the stars are aligned, I hear a hissing sound, and the wire seems to lose its outer shell leaving only the flux core visible. Settings seem a mystery.
    Re: Dual shield settings
    I usually crank it up hot around 75/25 settings and fine tune from there off the door chart. Takes a bit of twiddling to get it figured out.
    The "hiss" is what I want to hear.
    I think you're doing what any decent welder would do...….you're setting the machine to where it runs right for you. The stuff on the door is only a ballpark "suggestion".
    PDX PNW
    Lincoln’s settings for tig welding 1/8” joint says I should be at about 125 amps when really I was using 210 amps and it worked just fine
Page generated in 1,713,270,876.11995 seconds with 19 queries
