Results 1 to 6 of 6
Thread: HF MIG 170 Cap Mod Switch selection
    Jul 2019
    I've seen passing mention of using a switch to enable and disable the CE MIG 170 capacitor mod, but not much information on what kinds of voltages and amperages the switch needs to be rated for, and what gauge wire to use for connecting it.
    Is there a switch that can handle the current, or would adding a relay be the smarter option? Something like this, perhaps?
    https://www.ebay.com/itm/SSR-100-DD-....c100290.m3507
    May 2009
    Wyoming US
    Re: HF MIG 170 Cap Mod Switch selection
    The wires can be 10 gauge, a 50A switch will be fine.
    NAPA sells a switch , part # 786100
    Jul 2019
    Thanks, looks like they have it locally to me. I'm planning on using 6awg wire, what crimp connectors would be best? Most automotive-style don't seem to be up to the task, perhaps something like these?
    https://www.ebay.com/itm/20-Pack-6-7...AAAOSw7Phc-z2O
    Oct 2016
    I tried a 50 amp switch from the local farm store, with about 112,000uf
    it melted the internals down in just a couple welding projects. Same result with automotive 40 amp relays
    Went with this switch and been trouble free- probably a bit overkill, unlike the relays don't need another power source
    https://www.ebay.com/itm/300A-BATTER....c100005.m1851
    1962 Idealarc Tig 300 300
    1974 Idealarc Tig 300 300 ( till owner needs it back)
    1988 Power Mig 150 (.112 f cap mod)
    2015 Lotos Ltpdc2000d plasma/arc/tig
    Victor 100 torch, 200- 210 Oxy/Acet gauges
    Jul 2019
    Excellent, thanks. I'm a little annoyed that my eBay searches for switches didn't bring that item up. It's amazing how few high-amp switches there seems to be out there. Looks like it will accept 1/4 copper 6awg ring terminals, too.
    Jul 2019
    I ended up using one of those switches, has worked fine so far, but I've only done a few small test welds. You can see my implementation here;
    https://weldingweb.com/vbb/showthread.ph...-upgrade-REDUX
Page generated in 1,603,707,547.74273 seconds with 11 queries
