Results 1 to 11 of 11
Thread: ESAB REBEL EMP 215IC power board problem
    Sep 2019
    Hello to the esab forum. I am a new guy to the forum. Coming to get some help from your veterans.
    A little bit of background. We are a auto repair shop, we purchased the rebel emp 215ic a few years back. The machine stopped working a few month ago, no power up. I opened up the side panel, found a part on the main powerboard was burnt, soot was found all over the surrounding area.
    The question is, what the part is, I am guessing a thermistor. It is marked with VR1, right between line 1 and line 2. Since it was burnt really good, I could not find any mark on the part to know the real part number of the spec of it. Tried a lws, new board only, they don't repair the board, it cost more than a new machine. I did not take the board out yet, I will try to load a picture to show it better.
    thanks in advance.Name:  IMG_20190917_081601.jpg
Size:  131.0 KBName:  IMG_20190917_081728.jpg
    Jun 2011
    Aiken SC area
    Re: ESAB REBEL EMP 215IC power board problem
    Looking at the location of the destroyed part, it appears to be between the inputs, L2 and ?. Indicating to me that it is an MOV to protect the circuit from high voltage spikes, etc. The foil on the reverse side could also be blown off or damaged. They are sized according to voltage, 300,600,etc. This could be the only damaged part on the board but you won't know until you remove the board and examine the foil circuitry. Good luck, Bob
    Sep 2019
    Hi rhunt, thanks a lot for your input.
    Feb 2019
    Snyder TX
    Check with Inovat Corp.
    https://www.innovatcorp.com/
    Nov 2008
    This machine isn't too old. I don't think they will have them at Innovat unless there is a high failure rate. It may still be under warranty. Find out when you bought it. It has a three year warranty.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Feb 2019
    Snyder TX
    Innovat can repair the board - might be less expensive that a new one.
    Sep 2019
    Hi everyone,
    I finally received the MOV(390V, 20MM diameter for a greater survival amp) and had some time today to work on the machine. Replaced the burnt MOV, checked the continuity, one of the power switch blade shot too. It is a 25A rated switch in the machine, could only find a 15A piece. After checking everything, hooked to 240V, everything worked. Did not have much time, ran a few 6010, worked.
    So, I believe the high volt reached the clamping limit of the MOV and shot the MOV itself together with the switch. Cost $20. Thanks everyone especially rhunt for your input.
    Nov 2008
    That's good news. $20.00 is cheap for a welder repair these days.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Ceres, California
    Blown input MOV is not covered under ESABs warranty. Most of the time the cause is voltage spikes or wrong line voltage.
    Check you line.
    Sep 2019
    Right, high voltage for sure. Shop has 208 and 120 only. Just did not know what happened, it is a shop machine, lots of hands reach it.
    Apr 2016
    CA
    Hmmm... .. . Interesting repair... .. .
Page generated in 1,603,978,339.28052 seconds with 12 queries
