Page 1 of 4 123 ... LastLast
Results 1 to 25 of 76
Thread: Dry cut saws recommendations
    May 2013
    South of Dallas
    Im planning to buy a dry cut chop saw. I would like to hear what others have bought and their experiences.
    Aug 2018
    'ta town, KS
    Re: Dry cut saws recommendations
    I have a evolution rage 2... works for my uses.
    Mac
    Mar 2017
    Qatar
    Recommendations please! Carbide Chopsaw for the garage.
    https://r.tapatalk.com/shareLink?sha...8&share_type=t
    Miller Dynasty 280 DX TIGRunner
    Fronius Transsteel 2200
    Dec 2016
    I'm the one (one of) who asks all of the questions, so here's a chance for me to give something back.
    A year or so ago I purchased a Skilsaw Dry Cut saw 12". I looked at most everything out there to include: Makita (12"), Evolution (15") ( I own one of their steel cutting circular saws, too), MK Morse (14") and CS Unitec (14"). There are others.
    The CS Unitec seemed to be the most bulletproof and sturdy, but it's a bit pricier than the rest. I like the Evolution circular saw that I own, but their chop saw wasn't very compelling to me. Second place and it was probably a tie for what I was looking for, was Makita. They have great reviews.
    The Skilsaw is well-built and works very well. No complaints. I have found that you have to be very careful with the speed and material (how it's placed, etc.) you cut, as a few times the blade got snagged on the material, and it put a good size gouge into the base/surface. Hope this helps a bit.
    Feb 2019
    Snyder TX
    I have an Evolution & a Dewalt. The Evolution is a better saw IMHO. Seems to have a better base & vise.
    Iím really happy with my Makita.
    May 2013
    South of Dallas
    What are some good blades?
    Dec 2016
    New Jersey
    Makita LC1230
    I had a early model Evolution saw I bought on Clearance . I had to shim it for a square cut. I didn't like it at all.
    A buddy had the Milwaukee which is discontinued. Makita seems to be the favorite.
    IF you plan to cut sheet steel, the Milwaukee metal cutting circular saw is great !
    Laredo, Tx
    I have a Evolution 14" Rage 2 with the multi-purpose blade and it works just ok. The bad thing about is the weak clamping mechanism. It's just bent 1/8" sheet, as is the base. I'm eyeing the EVO SAW380 with a 15" blade.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Aug 2016
    Fein/Slugger 14”. Works great.
    LINCOLN Power MIG 210 MP
    LINCOLN Ranger 330 MPX
    MILLER Thunderbolt AC/DC
    HYPERTHERM Powermax 190C
    HYPERTHERM Powermax 45XP
    HOUGAN HMD 505
    HOUGAN HMD 130
    FEIN/SLUGGER 14" COLD METAL CHOP SAW
    Jun 2016
    SE Saskatchewan, Canada
    Really like my EVO SAW380, I reckon I have gone through over 20 blades in past 4 years. Learned the hard way how to get best life out of them. Have yet to try it with a 15" blade, but its on my list.
    I got it on Amazon, as where I also get my blades. Only tried 3 brands do far, Evolution blades are good, Concord are cheaper and okay for thin stuff, I think the best value is the Oshlun blades. (A quick look on Amazon has the Evolution blades same price as Oshlun at the moment so I would go with Evo).
    Red Seal Journeyman Welder (2003), Red Seal Journeyman Metal Fabricator (2018), Welding Engineering Technologist (2005)
    Pressure - ASME Section IX
    Structural - CSA W47.1, CSA W47.2
    Transport tanker - CSA B620
    Aerospace - AWS D17.1
    Makita lc-1230. For blades I like the original Makita but Milwaukee makes a real long lasting metal cutting blade.
    May 2013
    South of Dallas
    Quote Originally Posted by SaskWelder View Post
    How do you make the blades last longer?
    Laredo, Tx
    Quote Originally Posted by Millwrightdude View Post
    Generally speaking, make sure the part is clamped properly (even better if the part that is not typically supported to the right of the blade, is), cut slow, and maybe even use a cutting wax on the teeth if you're willing to deal with the clean-up. Oh and try to position the part so the blade is not engaging more material than it is rated for (IE: cutting square/rectangular tubing so that it is in a diamond "" orientation vertically, helps out more than cutting with the tube flat on one side ).
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    May 2010
    Sparks, NV
    I have had the EVO 355 for many years. Great saw. I believe they make The Morse saws as well.
    Jun 2016
    I couldn't have said it better.
    Great advise that also applies to BANDSAW blades.
    Apr 2016
    CA
    With blade life does applied pressure of blade against material being cut play any part or factor into the equation. I was under the impression that I should be applying light pressure to let the blade do most of the cutting and watch for sparks in that if there is a lot of sparks then too much pressure is being applied ?
    You just want a nice even feed, not too much pressure... a good blade will go right through easy enough but once it gets dull you will need some pressure.
    Apr 2016
    CA
    May 2013
    South of Dallas
    Im leaning towards the EVO SAW380
    Laredo, Tx
    Yup, the more I watch videos on it, the more I want it too.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Mar 2017
    Qatar
    https://www.trick-tools.com/Fein_Slu...aw_MCCS14_2180
    Laredo, Tx
    Cheaper, and they give you discounts on the 15" steel blade when purchased at the same time as the saw:
    https://www.discountsteel.com/items/...SABEgI2uPD_BwE
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
Page generated in 1,606,199,300.71898 seconds with 12 queries
