Results 1 to 14 of 14
Thread: cutting 15" diameter pipe
    Near San Antonio, Texas
    Any of you experts have any suggestions on how to set up a guide on 15" diameter pipe so I can cut off a couple of 12" sections. Tried fee handing and I am not worth a darn. I am using a Hypertherm PM 45. Some kind of strap for a guide?
    May 2007
    Re: cutting 15" diameter pipe
    a pipe wrap, soap stone, mini grinder, and cut off wheels. i use pferd #69963 (.040 x 6") for pipe, i can cut a 36" pipe .375 wall in 30 minutes, w/ a 13 amp mini grinder. itll take 3 $5 wheels. beautiful results
    If you have a good and to start with cut it from the inside with a length jig... but I'm guessing you already tried to cut so the end is probably a bit jagged
    Normally I'd just mark it with a sharpie or chalk by using at least a 1 foot wide piece of cardboard or something else with a straight edge, flexible and long enough to wrap it... you gonna need a bit over 4 feet long but 4 would be close enough to get it straight, just tape the center of one end on the pipe and wrap it...
    Nov 2012
    new york city
    Quote Originally Posted by txrpls View Post
    you said it. a strap to slide over the pipe. easy.
    i.u.o.e. # 15
    queens, ny and sunny fla
    How long is the 15" pipe ? Is there one good end ? Set pipe upright in flat surface and cut a 2x4 to required length to use as a guide to rest plasma on.
    Do you have a metal supplier or fab shop nearby with a 16x24 bandsaw or larger?
    They could square your end and cut two nice sections in little time.
    Jun 2008
    New Plymouth ID
    The guide for that size pipe will set you back some https://americawestdrillingsupply.com/TorchGuides.asp . A pipe wrap around and soapstone is how i would do it
    Thanks for the tip. I only have a 4.5" angle grinder, but cut it off using 4 wheels.
    Puget Sound, Washington
    Crappy but dirt cheap guide is plumbers tape pulled tight with a nut and bolt
    if not comfortable with soap stone as a guide, then use an HF ring roller to roll a ring to fit the pipe. use a drag tip. you could form 11g x 2" fairly easily by hand.
    I like that idea
    May 2007
    my mini grinders are 4.5" also. it just seems hard to get any work done w/ 4.5" cutoffs wheels. if your not used to them, maybe best you use the .045 x 4.5 " w/ guard. the part # of the 6" wheel i gave are more flexy/squirrlier than most ,(take some getting used too) but they cut like a mother ****er.
    Jun 2011
    BC, Canada
    What is the wall thickness? scd40???
    Quote Originally Posted by idacal View Post
    Wish I had bought some of them in the day, trying to cut vertical casing near ground level was always a pita with a wrap on the larger sizes. And standing on your head didn't help.
Page generated in 1,713,307,502.39531 seconds with 17 queries
