Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: DOT in Pakistan is cracking down on truckers
    Nov 2019
    North East Ohio
    Re: DOT in Pakistan is cracking down on truckers
    I could not drive that truck famersammm. Is the switch for a two speed rearend? A friend of mine used to drive an old truck from the 60-70's it had a 2 speed. I need to look at one of those. Does it have two different ring gears?
    No, that's the range selector. He has a 10 speed Roadranger… You go through the 5 gears once then pull the selector up to high range and go through them again.
    Two speed rears have one ring gear with a planetary unit in the differential carrier shifted by a small electric motor, air actuator, or in some of the older gas power trucks a vacuum actuator. Or in the case of a '48 Ford F-6 I drove once, a lever to shift it.
    Yeah, I have a vacuum switcher in my 54' gmc dump. never seen the lever shift ones but heard of em'.
    This old critter, 1970 with a 69 SA200 had the vacuum shifter too. It popped a diaphragm on me one day and I had to use vise grips on the hose to get home. Chevy dealer had it in stock, that I couldn't believe. Name:  20191201_113646.jpg
  5. #30
    Nov 2019
    North East Ohio
    Learn something new everyday
  6. #31
    Jun 2018
    NC
    Those guys must have some tough eyeballs.
    CR
  7. #32
    Feb 2010
    West Virginia
    Samm, I know it wasn't the grinding that caused that cracking. But I would be waiting to see how long that flywheel lasted., I can see it go kaboom quickly. And when I was driving, did just as you said.
  8. #33
    CT
    no glasses, no gloves, open toed sandals, lol. Bet he is good because he has to redo every job a week later , gives him plenty of practice. I am glad those trucks are separated from us by many miles and oceans so they never see our roads.
    "Si Vis Pacem Para Bellum"
    Lincoln Idealarc 250 AC/DC
    Millermatic 251 Syncrowave 300 30A spoolgun
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
    (2) Lincoln Weldanpower 225 CV
    (4) SA200 1 short hood SA250 SAM 400
  9. #34
    Quote Originally Posted by mrolds88 View Post
    I've never experienced a blown flywheel, Thank God. I can just imagine all those pieces coming up through the floor. I suppose your main protection would be the bell housing.
    I just really don't know what happens in this kind of situation.
  10. #35
    Jun 2016
    Back to the jungle
    Plus they totally abuse those trucks. Often way overloaded. Max load is when the bed is overflowing. Majority of the driving is probably diet
  11. #36
    Nov 2019
    North East Ohio
    I have naive question. If I recall he removed three layers of C channel or the equivalent. That is not how it came from the factory is it? To be honest the kid seemed to work well with the limited tools and materials and I tip my hat to him.
  12. #37
    Jan 2012
    West Rutland, Vermont
    I was a diesel mechanic some time long ago. I used to drive part time on the weekends for the same company. Best advise I ever got from an old driver was "your foot is either on the clutch on the floor or it's off the clutch". Never left him a clutch with no free play after that.
Page generated in 1,713,294,176.47059 seconds with 18 queries
