Results 1 to 4 of 4
Thread: Plasma cutter 62204/ 64808 ground cable
    Sep 2019
    So a friend asked me to replace the ground cable on that machine, anyone know how it is connected on the inside the unit ? just a lug or is it wired into a board ? Wire is only 10' 8 AWG and very stiff, he wants it a little longer and, more flexible…..any thoughts ?
    Thanks in advance.
    Delaware
    Re: Plasma cutter 62204/ 64808 ground cable
    Its bolted to the PCB
    Sep 2019
    Thanks for the reply, I took off the cover and see where it is located. Seems easy enough to modify, I'm thinking of putting a panel dinse
    connector on the front panel. Also I notice that when adjusting the max amp,led display only reads 33 amps...is that a problem or normal
    for a 40 amp machine.
    Dec 2016
    it should read whatever the machine is rated for.
    is it a dual voltage unit?
    i would put a amp clamp on it and compare readings.
    it's possible the readout is not calibrated very well.
Page generated in 1,603,706,007.90919 seconds with 11 queries
