Results 1 to 25 of 38
Thread: Acetylene only for brazing
    Oct 2010
    ohio
    Hello, my question, I want to braze not solder small mild steel solid rod such as 1/4 and smaller and small tube.
    I have a acetylene turbo torch. What size and type brazing rod do I need and I don't want to use solder.
    Thanks,
    Gary
    May 2017
    Re: Acetylene only for brazing
    Typically you use a rod the diameter as the thickness of your metal. For mild steel the usual rod is a bronze rod. It is actually a brass rod with flux on it, they just call it bronze. Or you could use a bare brass rod and add flux paste to the metal.
    Oct 2010
    ohio
    Thank you for responding. So this will work with acetylene only?
    So if I were to braze 3/16 solid rod, I would need 3/16 bronze flux coated rod?
    Sep 2015
    West coast of Florida
    Go HERE and click on the Filler Metal Selection Chart for the brazing filler and flux to use
    Richard
    Website
    Oct 2010
    ohio
    I don't want to use silver solder. Thank you for the link though. Silver solder is too expensive.
    Maybe, maybe not. Air/acetylene will likely require more heat input for bronze alloy than silver. More heat input equals more gas consumption.
    Also, what joint design matters.
    I as a standard use 1/8 bronze rod for most applications. And 1/16" silver at 45 percent.
    Sep 2012
    Wheatland, Wyoming
    On that small of tube I would use 1/16" brass rod.
    Chris
    Auction Addict
    Apr 2010
    rcairboater
    Quote Originally Posted by rcairboater View Post
    . . . I have a acetylene turbo torch . . .
    What is - 'a acetylene turbo torch' . . . ?
    Opus
    I don't have a "turbo" torch, so I don't know how hot they get, but I have an air-acetylene torch, and I tried brazing with it just for grins. All I can say is, "better pack a lunch," because you're gonna be there for a while, depending on the size/thickness of your base metal. I'd go with the smallest filler size I could find. And if you're concerned about the HAZ, this may not be the way to go, because everything is gonna get good and HOT for a good distance from the braze joint, by the time you get the joint area hot enough for the brass/bronze to flow.
    Personally, I would always use O/A rather than air-acetylene, since I have an O/A rig...you can get in and get out in less than half the time with O/A.
    rcairboater
    Opus
    It could actually be the brand Turbo Torch or any brand with a noisy swirl tip is often referred to as a "turbo torch".
    Air/Acetylene is not what you want especially a turbo torch. As mentioned it will take way too long to heat to temperature. Just went through this yesterday. Tried a turbo first and it wasn't concentrated enough to get metal hot enough to melt the bronze filler. Moved to Miller air/acetylene with single cone quiet tip and that was better but clearly not what is needed for brazing with bronze and while it did work I should have used Oxy/acetylene for sure. Thought I could use air/acetylene to use less heat and actually it ends up heating the entire piece so much more than just using oxy/acetylene because it takes forever. The pieces were really thin. Can't imagine trying with something with any thickness.
    Jan 2016
    northeast USA
    rcairboater
    Opus
    gee mr know it all doesnt know what a turbo torch is.. go google it....
  12. Dislikes shortarc disliked this post
  13. #12
    Jan 2016
    northeast USA
    this type brazing rod will work well with a turbo torch, a little bit goes a long way, if your using it on steel you will need to use a flux for brazing, on copper or brass you dont, but it wets in better if you do...I do alot of brazing of steel to steel, steel to copper and this works well with just a turbo torch either acetylene or map gas...
    https://www.amazon.com/Harris-Stay-S...VRMM0BK0RXAEX3
  14. #13
    Jun 2017
    AJO, ARIZONA
    Personally I dislike prefluxed rod, I would use 1/16 bronze with a can of flux, I think you will be much happier with the bare rod, I think it flows better/easier and you can control the fluxing action better.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
  15. #14
    Not trying to hijack the thread but can you braze with propane/oxy or do you need acetylene?
  16. #15
    Quote Originally Posted by txcarbuilder View Post
    You can braze just can't weld with it.
  17. #16
    Apr 2010
    danielplace
    thickness.
    Hobbytime
    My query = a 'Red Herring' AKA - Fishing . . .
    You swallowed the hook - all the way to your Vent - I set the hook . . .
    and pulled your Brains all the way forward to your Eyeballs . . .
    Metal: type/gauge - dictates torch type/heat = filler type . . .
    Opus
    ps -
    I first observed - a 'turbo torch' when the 'Cast-Iron Turd-Tubes' were
    rerouted under our house [concrete slab] to connect to the city sewer.
    I vividly remember the lead pot and pour [1960] . . .
  18. #17
    Jan 2016
    northeast USA
    danielplace
    Hobbytime
    Opus
    ps -
    blah blah blah..and you just swallow...as always you contribute nothing......but you have a hell of a good day.....
  19. #18
    Jun 2016
    Back to the jungle
    Heres a turbo/henrob/cobra/name of the month/ hunk of pistol playing with oxygen and acet ......on thin crap
  20. #19
    Jun 2016
    Back to the jungle
    No brass but good brain food
  21. #20
    Neither is the type of torch OP is asking about.
    That isn't the turbo torch be referred. Air/acetylene (one tank and atmosphere).
  22. #21
    May 2017
    Has Opus ever complemented anyone? And can anyone understand his comments? Does it appear that he is hallucinating when he writes that stuff?
  23. Likes R&I liked this post
  24. #22
    Jun 2016
    Back to the jungle
    I'll take Opies side on this. Never heard of it and don't want to.
    Oxy propane was like an ingrown toenail to me. Idiocy. Hire the cutting done
  25. #23
    Feb 2012
    Sweden
    I don't want to use silver solder. Silver solder is too expensive.
    Maybe it is, maybe it isn't.
    Bronze brazing rod has a relatively high melting point, you need a torch that can bring a large enough area of whatever you are trying to braze to cherry red. For me that usually means I need my O/A welder, as my hand held propane torches only can get very small items hot enough, and that's under ideal conditions. Acetylene is expensive, the oxygen costs a bit too.
    Silver brazing rod with large amounts of silver melt many hundred degrees earlier, and unlike the bronze it likes tight joints that it can be sucked into by capillary action. This means you need way less rod for many joints, and a relatively small torch that burns really cheap propane often gets the metal hot enough.
    Silver brazing rod is absolutely expensive. But so can the heating be, just like the time you spend doing the job, so when you factor everything in you may find that using silver brazing rod becomes cheaper. Especially if it's the difference between using a cheap propane torch and being forced to buy a O/A welder.
  26. #24
    Good points, G-son, I agree. I might also add that a properly-done silver solder joint can be dam near as strong as the steel it joins, if not stronger...
    And you can silver solder all day long with nothing more than air-acetylene.
  27. #25
    They are great when you need something a little milder than oxy/acetylene. This is a soft flame tip with defined flame cone that allows you to concentrate the heat the turbo torch tips do not have a single flame but rather a swirl tip multi flame. Very useful tool to have.
    One tank, one valve and no need to adjust flame as it is neutral automatically.
  28. Likes tapwelder liked this post
Page generated in 1,713,310,408.02889 seconds with 18 queries
