Results 1 to 10 of 10
Thread: WTB thermal arc 185tsw
    Mar 2009
    I am looking for a bad thermal arc 185. I burnt a board in mine and cant see paying $1000 for a new board. I was hoping someone had a non working one and I could take two to make one good machine again. I would like a new machine but am not in the place where I can spend $2000 right now. Let me know if you have one. Thanks.
    Mar 2017
    Dubai
    Re: WTB thermal arc 185tsw
    Is this the board you're looking for?
    https://rover.ebay.com/rover/0/0/0?m...2F233376469810
    Mar 2009
    Unfortunately no. I need the main board. The part number I need is 10-6634. I will send that guy a message. Maybe he will have one. Thanks
    Jul 2016
    Midwest
    That's a Sanrex machine. I have a non working 200 if you can use anything off of it. It looks the same but is slightly larger. Needs Igbt's.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    Mar 2009
    I looked it up and the main board has a different part number on the 300 vs the 185. I then looked at the IGBT to see if I could help you out. And again they have different part numbers. Thanks anyways but I guess the hunt continues. A place call Midwest welding supplies has a lot of thermal arc parts and can get any parts you would need. But I can’t see paying $1000 for a new board when I can get a new miller or Lincoln for a few hundred more.
    Pueblo, CO
    I was always curious about the several companies that rebuild circuit boards. They are supposed to be considerably cheaper than buying a new board.
    Have you checked prices at any of those companies?
    I just got this one from Google: https://www.innovatcorp.com/
    Just a thought.
    Steve
    EDIT. I googled welder circuit board repair
    Mar 2009
    I have talked to them personally. I exhausted every way to fix my machine. That company only deals with the big names. They can’t get the info they need to fix thermal arc boards. So unless someone finds another company that can my welder is scrap and I will be forced to buy a new one when money allows
    Jan 2005
    Rondo has a 200 not a 300 thermal..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
    East Durham, NY
    I know welders are not the same as furnaces, but.................. I needed a board for my furnace, my brother had one, but with different numbers. BTW, he is a repair man, knows what he is doing. Anyway, even with different numbers, visual inspection of both showed they would interchange. Different years, options, etc, there will be slight differences. But if all your basic/needed connections are there, there is a very good chance it might work. First step, which I did, was to look at pics of both and compare connections, etc, Bottom line - what do you have to lose by trying this?
    Jul 2016
    Midwest
    I know the 185, 200, 300 Sanrex units. The 200 board is likely a little larger than the 185 boards and probably won't fit in the case.
    Cobra Pythons
    Victor Gas Apps.
Page generated in 1,713,299,955.58251 seconds with 19 queries
