Results 1 to 16 of 16
Thread: Old Stick Electrodes Worth Keeping?
    Jan 2020
    Cincinnati
    Hi Guys,
    I ran across some old stick electrodes the other day cleaning out my garage. I don't know much about stick welding, nor do I own one, but I do plan to get one at some point in the future. Are these welding rods worth keeping to use at some point or are they junk? No idea what kind of electrodes they are, but I did include a number of pictures to help identify. If they are junk, can you scrap them or do they go straight in the dumpster? Thanks!
    Jul 2011
    Bossier Parish La.
    Re: Old Stick Electrodes Worth Keeping?
    What numbers are on the side of the rods near the bare end?
    Most work it work great.
    I would put in oven for few hours just dry out the rod.
    Quote Originally Posted by WeldCrazyDude View Post
    Hi Guys,
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Sep 2016
    Detroit, Michigan
    Heck yeah you should keep those! Obviously you wouldn't want to use them for code work, but for most anything else they should be fine. If the flux isn't crumbling off they should still work. That McKay Hardalloy 55 is a hard-facing rod for building up things like loader bucket cutting edge and teeth. Buying that sort of rod is pretty expensive, and handy to have around just in case you get an oddball project. I don't recognize the other packaging, but the rods should be marked. Worst case they'll be great for practicing when you get a stick welder.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Just don't try to use it for anything structural, because it has like zero ductility!
    Jan 2020
    Cincinnati
    Looked a bit closer and the markings i see on different rods are:
    6013
    11018M
    6012
    7011
    6013
    11018M
    6012
    7011
    https://www.red-d-arc.com/pdf/Weldin...ifications.pdf
    Oct 2012
    East Van BC
    Ooh eleventy eighteen! That’s a keeper! I would keep them all. Those are perfectly good rods.
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Boice-Crane Band Saw
    Victor O/A
    Jan 2020
    Hardfacing rods are usually more tricky to run in my opinion. Probably not the best to practice with
    Sent from my SM-G970W using Tapatalk
    Apr 2016
    CA
    7011 is that like a 6011 with 10k more tensil strength?
    Well.... not necessarily
    Sep 2016
    Detroit, Michigan
    True....I should have been more specific. An oddball project that calls for a hard-facing rod
    http://mivise.com
    Brethren, Mi
    I make stuff from them.
    Mar 2015
    You betchee,they never get too bad for that,,,,,,,,,unless they rust,and I just sand it off and useum anyhow. Old and partially used rods in various diameteirs are my go to for gap fill backer.
    Apr 2016
    CA
    Quote Originally Posted by Jax View Post
    Interesting. I bet that'd make a good Youtube vid, Shade Tree Welders gone crazy j/k sounds like something I'd try now that I've read about it on the forums.
    Brethren, Mi
    The hard rods are really strong. Put old piece of hose over, bend, lots of ways to hang or attach them.
Page generated in 1,713,282,663.22498 seconds with 18 queries
