Results 1 to 11 of 11
Thread: filing on aluminum
    Arizona
    filing on aluminum
    I need some square holes in some 1/4" aluminum diamond plate for carriage bolts, I don't see any aluminum files small enough to do it. I already drilled the holes 3/8" just need to square them up, will I ruin my steel files? Only 8 holes total.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    Fredericksburg, VA
    Re: filing on aluminum
    I think the files will be fine.
    Have you thought of grinding a tapered square punch and just using that to square the holes?
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Arizona
    I have one that I made a while back but it's just mild steel, may try it. I also thought about centering the hole over the pritchel hole on my anvil and dropping in a carriage bolt then giving it a good smack. I have some scrap of the aluminum I will try both this weekend and see how it works, Thanks.
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Soda springs,Id
    Measure the square diagonally and drill the holes out a little smaller than that and drive them in. It's what I do when it's time to replace the cutting edge on my wheeler snow plow.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Sechelt, BC
    File card:
    Jun 2019
    BZN
    Your files will be fine. If they gum up you can just take a steel-bristled brush over them to clean out the aluminum bits. Using some WD-40 or tapping oil can help prevent gumming up but, if it's just 1/4" plate, you probably won't have a problem anyway. I've used the same file set on aluminium, brass, steel, copper, plastics, etc, for the last 10 years. Never had an issue between materials. Never heard of an alum specific file but, I'm someone sells one.
    Arizona
    Well I tried using a carriage bolt and a BFH with the holes over the pritchel hole on my recently acquired Mankel 115 lb anvil and it worked great! Sunk them right in for a perfect, tight fit. The holes are near the edge and I was afraid the tapered square punch might break the aluminum. Thanks for all the advice.
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Mount Tabor VT
    Machinists use a brooch (sp?) It's a tapered piece of hard tool steel with notches cut in it.
    Aug 2013
    Hudsons Hope BC
    coat your file with chalk when you are filing aluminum copper or brass.
    it will keep the the teethical clean.
    Lincoln 350mp
    miller regency
    miller syncro wave 300
    Nov 2004
    Southern Montana
    Broach.
    Jan 2008
    PNW/Kodiak
    Unless you’re working with aluminum a bunch, probably not worth the investment...
    But these work phenomenally:
    http://www.cleavelandtool.com/mobile.../#.Xi6JKiSUuaM
    Do you really know all of the work that goes into getting that fish onto your plate?
Page generated in 1,713,308,657.83410 seconds with 18 queries
