Results 26 to 35 of 35
Thread: Stair Railing Layout and Measuring
    Re: Stair Railing Layout and Measuring
    Nice rails. What is the time difference in fabrication Aluminum vs steel rails? how do you weld them? How do you treat butt joints that need to be flush welded?.... this is an issue that seems to fail in many beautifully done rail. I have done several repairs on Ally pipe rails that fail at joints.
    I spent a day just making the top rails, bending, splitting the rail to make the lamb's tongue, rolling the ends, filling the underside in to make them look solid and sanding them. That is a thin aluminum skin welded to the backside of the top rail to make them look solid.
    Attachment 1710954
    Attachment 1710955
    Sincerely,
    William McCormick
    Thanks. I will try bid some ally rails. I have noticed on repairs no real prep.I usually clean breaks. I was recently on site doing an install, I noticed some ally pipe rails that were installed 10 years ago. I had admired the quality of the work at the time. Now they are broken apart at several joints.
    No not if you penetrate the joints. Like I said most guys just do a cosmetic weld. You have to go slow and let both base metals mix and then add filler then you get a gnarly weld that can be a pain in the *** to remove if you put it in the wrong spot.
    Sincerely,
    William McCormick
  4. #28
    There is no rule that says the rise and run of the steps has to match the actual pitch of the step.
    How do you measure 10 foot rise steps inside a house?
    Nice rails. Compound bend, well done. Oh, you removed a similar rail. looks like water infiltration/ freeze in balusters, newel and bottom rail.
    They had already removed the center rail, all that was left was the little two top rails that I cut off and cored around and removed the pipe stub in the ground, and then I filled in the holes, and then re-cored for the new rails.
    Sincerely,
    William McCormick
  6. #29
    Mar 2007
    MidWest
    This is how you measure stairs for railings, you can use baseplate or core drill.
    My example shows a railing less than 6 ft with 2 posts, but in reality you wouldn't need the middle post, it's just for illustration purposes,
    https://uploads.tapatalk-cdn.com/202...8c4f2b9da8.jpg
    I can't stress this enough
    You do not need a digital angle finder,
    You do not need baseplates with 1x1 tubes welded to them, all you need is a level to take the measurements
    If you take any more measurements or angles than what I have drawn, you're wasting time.
    I realize this is very basic, but not obvious to me. What is the significance of the 36" and 21" measurements. I ask because I have couple handrails to build at my house and want to lay them out properly. Thank you
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
  7. #30
    Quote Originally Posted by geezer View Post
    If steps are at.your house, the lay the out on the steps. Using a template is the best layout tool. It is no always practical and often time consuming.
    In the sketch the numbers represent the pitch/angle of the steps. He just used 3 rises and 3 treads.
  8. #31
    The 21" represents the drop from the top of the stoop to the middle step that is going to have a baluster, upright, or vertical, mounted to it. The 42" represents the distance from the top of the stoop down to the last step where another baluster, vertical or upright will go. The 36 represents how far from the front edge of the stoop horizontally to the front of the middle step, where the baluster, upright, or vertical, will go. The same for the 72.
    I used to measure using the least amount of input myself. Then as I got older I realized that if I took all the measurements I could even figure out a bad measurement from all the other measurements in most cases. Did you ever scribble something and later not be able to read it? I have, I note things like are all the steps pretty much the same length and all about the same height. Then when I go back if I have one step that is off compared to all the others I can figure out what it was supposed to be. I measure a stoop with every measurement there is to it in under seven minutes. And I have never had to go back.
    Sincerely,
    William McCormick
  9. Likes ronsii, tapwelder liked this post
  10. #32
    Mar 2007
    MidWest
    Sincerely,
    William McCormick
    Thanks for taking the time to respond. I have often viewed your railing and stairs posts, first class. MetalMan great work also. I was not sure if the numbers were a contingency for additional uprights or used otherwise. Too basic of question, i should have scratch my noodle a little longer. Thanks again for responding.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  11. #33
    Sep 2008
    Dalton, GA
    Quote Originally Posted by J93Welder View Post
    Hello all, Iím ďnewĒ here. Well, new account as my old one got deleted. Anyway, I just bought a house and it has a nice deep garage that I can set my shop up in to do side work and Iím looking to get into railings for residential/commercial.
    I work in aviation now, which is repetitive and mostly JUST welding. I did do hundreds of railings before at a prior company but never measured in the field, was mostly working off CAD drawings.
    I will admit I am fairy rusty on the layout aspect, and was wondering how you guys measure and lay out for stair railing. The info is limited for what I can find. I saw one that made sense, was a guy on a Kings Metals video and he has a standard 4x4 baseplate with a small 1x1 tube welding in the middle, and he put these on the blank stair case where they would go if a railing was there and measure the points on the slope and the straight.
    But I remember doing a ton of math when I even had the railings all drawn up and I just donít want to make a mistake with a new customer. I was thinking this was a good way to measure, and then getting an digital angle finder to use on the treads and my layout should be good? Plus 36Ē height for code, no more than 4in picket spacing, etc.
    If you have any tips for layout please post it up. Or if you have any insight on how to get these kinds of jobs. I joined some neighborhood forums to advertise that Iím a welder in the area, but if you have any more tips that would be great, thanks!
    To the original posterís question:
    Since I am neither school trained nor building expensive, complex rails, on the 20+ porch railings that I have built I used a 2x4, level, and an angle finder to create a story board. Laying the board on the steps, I use a marker to mark the front edge of each step, a level to mark plumb for the posts, and angle finder to mark the angle. At my small shop I use this story board plus my field notes to layout the rails. Since my confidence needs some confirmation, I have often taken just the shell back to the job site for a test fit before going too far. Actually never had to adjust but helps my peace of mind. Also the hardest part for me is to determine the exact post height from the step/landing to the bottom rail. I have found it easier to get the shell blocked plumb and correct height off step nose on-site, then tack the posts. I expect you pros will get a laugh out of my primitive methods but it works for me. A little effort and ingenuity can compensate for CAD programs and school trained engineering.
    Anyway, my customers have all been well pleased with the results. I only wish I was able to do some of the rails pictured above!
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211 w/Spoolmate
    Miller 375 Plasma Cutter
    Miller Thunderbolt XL AC/DC
    Hobart Handler 120
    10FtDrillBit.com
  12. #34
    Yea there is no right or wrong way, it is what works best for you. Your method definitely works I used a method like that when I built my son's steps but in reverse. Since I had the measurements of the stairs from the Cadd drawing, I just went down the stringer and marked where to put the tread mounts.
    The only problem with angles is preserving the angle on some device until you get back. If you are doing two-step stoops I could probably guess at 33 to 34 degrees and be right 95 percent of the time. But when you have to do it by an angle for four or more steps it is not easy. One degree means a lot over four feet, and a little knot in the 2x4 could throw you off by more than that. If you have ever cut rafters you know that the whole process is done without angles and it is done for a reason, angles will F-you-up, maybe not today maybe not next week but when they do I will be able to hear you yell states away.
    When I build pipe rails I use a protractor from Starret, but I have exact angles from the Cadd program, and a, metal to metal, way to check them. And it still gets hairy sometimes I silently bump the protractor on something even myself and that strange yell you heard that was me haha.
    Metal master is the guy to follow if you are doing quality wrought iron rails, especially if you are making and installing two sets a day, you do not have seven minutes to measure doing that king of work. I had to measure two jobs on the way back from picking up material. I had no pencil, no tape measure, no level, I found two pieces of rolled-up cardboard put it up against the stoop and rubbed the cardboard until the stoop and steps made an impression in the cardboard. One stoop on each side of the same pieces of cardboard, haha. The things we do for metal products.
    Sincerely,
    William McCormick
  13. Likes ronsii, sr guy liked this post
  14. #35
    Mar 2007
    MidWest
    I'll make some more drawings tomorrow to show you the fabrication aspect of it, and how to stay 36" high while transitioning down stairs.
    I realize Phil is super busy with work and building a very respectable welding truck, so I am not going to bother him, but I am just wondering if he completed any additional drawings showing the fabrication. Obviously I have a few handrails to do and the info would be value added.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
Page generated in 1,591,130,531.13451 seconds with 14 queries
