Results 1 to 5 of 5
Thread: SAM 400 struggling to get an Arc from need
    Apr 2020
    Howdy Im Cody Elbel, Texas struggling to get a SAM 400 welding that i own. I purchased it for very little and it has next to no hours. the coils are good and machine has a great engine in it. Engine is a perkins 4.136 four cylinder. So here's the problem, no arc, no outlet power. when i got it the blue and browns were chopped off and i though. this will be quick. I got them to read 10 ohms, there good. I have seated my brushes, and they are good. Does anyone know step by steps in human termanology to getting one to going. its a very nice machine would hate to have to part it out. My armature is also good, did ground test, new bearing. lets start simple I know I need outlet power what should I check?(it is ac machine excited) outlets worked before i did teardown and i didnt break anything while going thru machine.
    Re: SAM 400 struggling to get an Arc from need
    You probably checked already but does it have a local remote switch? Have seen simple things like that drive people crazy.
    Ceres, California
    Find the code number and call Lincoln tech support and ask a diagram set. then double check all the wiring you disturbed.
    Most of the time you will either find a disconnected wire or one wire in the wrong place.
    You have to call to get the correct diagrams for your welder. the on line owner's manuals have general diagrams.
    Emailed diagrams are normally free.
    Apr 2020
    the machine has a jumper wire in place currently. I have a schematic however I lost excition. i can get it to excite again that shouldn't be a problem but all i was getting initially when i started was sparkling rod. Again coils are good at 10 ohms. The exciter isn't working probably due to the flash wire. I have been told a bridge rectifier could be the problem. Any further ideas?
    You might be able to find a manual online with a troubleshooting guide or get some info from Lincoln like suggested above.
Page generated in 1,594,101,703.62241 seconds with 11 queries
