Results 1 to 6 of 6
Thread: Miller 180k no arc - low or no voltage to receptacles
    Jun 2016
    Miller model Blue Star 180k welder/generator - gas engine runs well, stinger quit arcing during a job. Seems like less than four volts AC at the receptacles. Any ideas?
    Jun 2016
    Re: Miller 180k no arc - low or no voltage to receptacles
    Miller Blue Star 180K - If anyone knows how I may access/purchase a shop service manual or troubleshooting/parts manual for this unit it could save me the steep learning curve. Thanks in advance.
    Feb 2019
    Snyder TX
    Miller web site. Search for BLUE STAR 180K
    https://www.millerwelds.com/support/manuals-and-parts
    Jun 2016
    Thanks, I will check it out.
    Jun 2016
    cwby: Thanks, I did find some general information in the operator manual at millerwelds.com. I have tested the fuse and the diode bridge for the exciter circuit. These test ok, so I must go deeper and check the rectifier windings and brushes/slip-rings.
    Jun 2016
    Checked brushes, exciter ohms, etc. and everything fine. Finally found the cause of the outage: Vibration had rubbed two wires through their insulation, shorted, and perhaps fried something on the circuit board.
Page generated in 1,607,081,456.96946 seconds with 11 queries
