Results 1 to 19 of 19
Thread: Tig pedal question
    Apr 2007
    Tig pedal question
    While welding at a work bench, I had a piece of steel fall off and cut the wires to my pedal right in half. If I just splice the wires back together, will that affect the operation of the pedal? I did strip the wires and twist and tape them back together just to finish what I was working on but my weld quality has seemed to go down since then. Not sure if the pedal being patched back together is an issue or if its just a lack of hood time and its me. Just wanted to get some thoughts.
    Dec 2003
    Fairfield,CT
    Re: Tig pedal question
    This happened to me twice already. I soldered and shrink tube my connections. All is well. Not sure about your repair procedure.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Nov 2012
    North Carolina / Maine
    If you don't want to solder and heat shrink a repair you just about have to use wire nuts to make the connection secure enough to guarantee it will work. Currents transmitted in those wires are pretty small and any dirt or corrosion on the wires could easily interfere with proper transmission of the signals.
    Ceres, California
    If you cut the wire close to the peddle. Open the peddle and splice the wires inside. Small butt splices work best.
    This way the splice is protected from movement and further damage. If splices are made right welder should work normal.
    Depending on the TIG welder. cutting through the cord and causing a short circuit can damage the welder.
    Most of the time the remote foot control will not work at all. but Panel control still work fine.
    All depends on what may have been damaged by the short.
    Mar 2005
    Under a Rock
    Tig pedal question
    Wire nuts !!!
    WTF
    Good Grief....
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Nov 2012
    Yes wire nuts!! More secure than twist, tape, and pray!
  7. Dislikes TraditionalToolworks disliked this post
  8. #7
    San Jose, CA Kelseyville, CA
    Quote Originally Posted by Dobermann View Post
    Pzzzt...wrong answer.
    This is not the place for a wire nut. If for some reason someone doesn't want to do a proper solder/splice with heat shrink, there are butt splice crimp connectors like these:
    There is really no shortcuts on this type of repair, you either have or buy a soldering iron or have or buy a crimper. Who needs to disconnect these wires, they're meant to be connected all the time. My $0.02...
  9. #8
    Nov 2012
    I'm not advocating wirenuts as a fix--only that it's better than twisting raw leads together and taping them--which will most certainly pull apart the first time somebody trips over the cable. And, in my humble opinion base on lots of years of electrical work, there are two kinds of crimped butt connectors--those that have failed and those that are gonna fail. The correct fix is (a) strip, clean, solder, heatshrink with adhesive tubing (b) cut out the damaged piece and re-attach at either end (plug or pedal) or (c) replace the cable.
  10. #9
    Mar 2005
    Under a Rock
    I'm not advocating wirenuts as a fix.
    Nice BS back peddle....
    The correct (and obvious) answer is solder and shrink tube. (Preferably glue filled shrink tube)
    Fuggin wire nuts !!!!
    LMFAO...
    Do yourself a favor,
    Remove that word from your vocabulary.
    Hypertherm PM 45
    HTP 221
  11. Likes TraditionalToolworks liked this post
  12. #10
    Mar 2005
    Under a Rock
    PS
    If you can weld ... in any capacity
    You certainly should be able to solder a few wires...
    Hypertherm PM 45
    HTP 221
  13. Likes TraditionalToolworks, cornemuse liked this post
  14. #11
    Ford has a special tool and crimp couplings for making repairs to damaged wiring harnesses on vehicles. They also have a special tape for wrapping the wires up. Do you know any Ford techs? If not soldering is the best. I worked in a shop where an idiot they had hired as a foreman hard wired a 3 phase welder to the box instead of getting the proper plug and receptacle. The cord was also too short so he attached a 20' extension cord using wire nuts and electrical tape and ran it across the shop floor. He thought it was perfectly fine having his splice laying in the middle of the shop floor. You can't fix stupid!
  15. #12
    Nov 2014
    Southern CT
    LMFAO...
    John, tell us what you really think of wire nuts .
    When I was just a puppy years ago I worked in the trade. Old old houses wired before BX, plastic jacket cable and wire nuts were invented were wired with rubber/fabric covered wires run in porcelain fixtures, no ground! I came across many original splices, usually 14G wire that were stripped and twisted tight about 1-1/2" to 2", then soldered, wrapped in sticky rubber tape followed by the old cloth friction tape. Kind of overkill. There was no untwisting anything and the rubber-friction tape was fossilized anyway.
    Old timer I worked for told me they used to solder the wires with a mouth blown alcohol torch!!
    Ernie F.
  16. #13
    Nov 2012
    You nay sayers best not be looking in the outlet and switch boxes in your house! You might stumble over the odd wire nut!
  17. #14
    The repair in question isn't inside an electrical box.
  18. #15
    Ct
    Hey don't make fun of wire nuts, they're keeping things together
  19. #16
    Nov 2004
    Southern Montana
    Other than it may be a poor choice to connect small diameter wires, such as those for pedals, I'm wondering if using wire nuts is generally bad. If so, can someone explain?
  20. #17
    They have a purpose and a place, generally inside electrical boxes. Out in the open they aren't recommended.
  21. #18
    Nov 2013
    If you go to Home Depots plumbing department, where the Well stuff is, you can find Splice Kit for submerged well pumps. These kits contain 4-crimp sleeves, 4 pieces of Thick heat shrink (glue lined), and 1-heat shrink (this one Very Thick and also glue lined) to go over the 4 connectors. This is all really heavy duty stuff and a great source of rugged splice you'd never have to worry about...
  22. Likes metalman21 liked this post
  23. #19
    Dec 2003
    Fairfield,CT
    Ha. HD. Walk in there and ask where this repair kit is and then they ask you. What pump is this for. You say, for my TIG pedal as their eyes roll back in their head.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
Page generated in 1,594,721,039.18066 seconds with 13 queries
