Results 1 to 2 of 2
Thread: Tweco/fireball/esab consumables!
    Mar 2015
    Hey has anyone or does anyone have or has converted or swapped out or an adapter kit for the tweco 200 fusion gun for more common consumables like Hobart or Lincoln style? Where I am the fusion consumables are expensive and not easy to find so wondering if there are converters for gun or any info on swapping the whole gun out? I have never done this and I've tried search on google for the last 45 minutes to find nothing on it any input would be awesome thank you!
    Jul 2016
    Midwest
    Re: Tweco/fireball/esab consumables!
    If you are talking about the 250 spray master fusion gun then yes, Just throw in an original Spraymaster goose neck. Any amp range 250, 350 or 450 amp. You will likely want the 250 amp 11 series front end parts. If it's the china fusion gun then you need a different gun. If you do have the Spray Master version there is an allen screw on the side of the handle toward the front. A half turn and the neck pulls right out.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
Page generated in 1,604,172,613.80036 seconds with 11 queries
