Page 5 of 6 FirstFirst ... 3456 LastLast
Results 101 to 125 of 131
Thread: Best method to drill hundreds of holes
  1. #101
    Dec 2003
    Fairfield,CT
    Re: Best method to drill hundreds of holes
    Also revisit TJS' video at 22 seconds where he shows his original jig. Simple and accurate.
    Thanks. Here is a vid of the jig in use.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
  2. Likes Lis2323 liked this post
  3. #102
    Nov 2019
    North East Ohio
    Thank you
    Correct
    No center punch. I figured that defeated the purpose of a jig.
    Correct. BUT if I had the setup elevated I think I would have tried drilling through both walls with a 2” doc cutter.
    Hougen HMD 905
    What hole spacing are you using for the squat rack?
    A 5/8 hole every 2". If I get this to a smooth process, I would go every 1" in the bench zone. The company Rogue is the big seller of gym equipment. Everyone want their rack like them, people think theirs is the only way. I'm only 56 i recall the primitive stuff we used. Makes me laugh people think they need all the bells and whistles. Rant over.
  4. Likes Lis2323 liked this post
  5. #103
    Nov 2019
    North East Ohio
    JTS
    Thank you for sharing. Great set up.
  6. #104
    Hereís an update. It lacks the precision of JTSí nicely machined guide but it actually works.
    The new vertical stop will be bushed to accommodate different hole sizes. It is easily located at one inch increments at which point only the vertical pin needs to be inserted in the last hole drilled for correct spacing.
    There is no limit to length of material that can be accommodated.
  7. Likes frieed liked this post
  8. #105
    Nov 2019
    North East Ohio
    Lis 2323
    I like that a lot. Just slide the work piece until it hits the big stop and/or drop the pin in the last hole drilled. Is that what I should be seeing?
  9. #106
    Lis 2323
    By sliding the square tube and INSERTING the pin in the LAST HOLE DRILLED you should be able to accurately duplicate your hole spacing regardless of workpiece length.
    Iím certain this design can improved on but iwhat do you expect from a farm shop
  10. #107
    Oct 2013
    Long Island, NY
    The specific spacing you're looking for I believe is "westside hole spacing" after westside barbell.
    Rogue makes excellent quality equipment but its definitely pricey for home use. They do most things in house with a CNC tube laser.
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  11. #108
    Dec 2003
    Fairfield,CT
    I’m certain this design can improved on but iwhat do you expect from a farm shop
    Are you able to drill through both sides of the tube at the same time. I think I am going to steal your design cause I have another gate to build and using a mag drill might make it more portable for me as well. Thanks. I might make it so I can go thru both tubes at the same time.
    T.J.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
  12. #109
    T.J.
    Should be able to, yes. I didnít try it for the photo as I didnít have the 2ĒDOC cutter in the drill.
    The whole assembly would need to be elevated slightly to allow the annular cutter to break through or clearance provided beneath it.
    Iím certain you will find the process way quicker also as the drilling only took 2-3 seconds and another 10 seconds or so to slide the tube and locate in the next position.
  13. #110
    Jun 2009
    Draper, UT
    Because of this thread I now have these:
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
  14. Likes Lis2323 liked this post
  15. #111
    Quote Originally Posted by frieed View Post
    Awesome. NOW order yourself enough arbors to have one dedicated for each cutter.
    Try using a few different sizes on a project and you will thank me later.
    Youíre welcome
  16. #112
    Okay the jig I made today actually works quite well. The unistrut allows for spacing of 1Ē increments.
    Where was the precision loss on this?
    Designs I have seen jigs similar to this with pins as stops that were spring loaded. Multiples stops are set. The metal is inserted to its furthest hole then drilled. Then pulled back until the next stop engages, them drilled. Then repeated.
  17. #113
    There was no precision loss. The pin is lifted out and reinserted manually. Still foolproof. Spring loaded pins would be ideal.
    Please keep in mind I just mocked this up as an experiment trying to help the OP with a device that could be fabricated by fellow NON pro.
  18. Likes VaughnT liked this post
  19. #114
    Nov 2019
    North East Ohio
    West west side Lou Simmons. Check him out on YouTube. I have never meet him but friends of mine have. Guy is a pioneer of power.
  20. #115
    Nov 2019
    North East Ohio
    Lis2323
    This is exactly what I'm looking for. I can use this jig to make 96" squat stands and NOT have to move it. Move the work piece. Nice small footprint. "Pull the Pin slide drop the pin and dril"
  21. Likes Lis2323 liked this post
  22. #116
    Reebz. Happy to be of help. Iím certain you will find ways to fine tune or make it even more user friendly!
  23. #117
    Got it. In previous post you said it lacks the precision of... I was just curious where it was missing. Perhaps no misunderstood?
  24. #118
    Haha. I looked back at my post. I was comparing the precision of my welded clip on guide to the nicely machined one TJS shows in his video.
  25. #119
    Lis2323
    Reebz. Are you planning on buying a mag drill? If you are, you are welcome to this jig. I can send it out to you (on my dime of course)
    You may need to change the containment platform depending on the dimensions of your drillís base.
    PM me.
  26. #120
    Nov 2019
    North East Ohio
    Thank you for the offer. I will try and make one. I'm not sure what drill to get at this point. I do drill (95% 5/8 holes) (4% 1 3/8" holes) (1% 2 3/8")
  27. #121
    A 2 3/8Ē hole saw may work with a drill chuck adapter on a mag drill. The other two sizes would be affordable and efficient with annular cutters.
    Let me know if you change your mind, as you are more than welcome to it.
  28. #122
    Nov 2019
    North East Ohio
    That very nice of you. I have to check on annular cutter sizes. My local wedding store sell Fein drills. I will get a price Wednesday. If its to much I talked to Hougen they recommended the HMP 917.
  29. #123
    Nov 2019
    North East Ohio
    I just looked at the price for a 2 3/8 annular. Hole saw it is.
  30. #124
    I kind of figured.
    Whatís the BIG hole for? Radius for the ďjĒ hook?
  31. #125
    Nov 2019
    North East Ohio
    The 5/8 are for J hooks, The 1 3/8 is for pipe to make chin bars, the 2 3/8 is for sleds the 1.5" pipe fits perfectly into 2.38 DOM.
  32. Likes Lis2323 liked this post
Page generated in 1,604,064,128.75836 seconds with 13 queries
