Results 1 to 18 of 18
Thread: How to cut tungsten?
    Apr 2020
    AntHome 92025
    Tig newby here. I recently acquired a #9 torch and a 7" tungsten is too long to fit inside the end cap.
    So I need to cut some in half for use in this torch.
    My bandsaw shatters them. They take the sharp angle off the edge of the grinding stone (wears the stone really fast). They are too long to fit in my ebay rotary tool sharpener.
    Suggestions?
    TIA,
    robert
    Feb 2015
    Re: How to cut tungsten?
    I would suggest an abrasive cut-off wheel on a 4 1/2 inch anglehead grinder. Or use one in a die grinder. (One that is made for the die grinder.) Sometimes they are called zip disks, some call them Metabo wheels,etc. No matter the name, it is simply a thin abrasive disk designed to cut on the edge of the wheel. Good luck!
  3. Likes BD1, robert-r liked this post
    Laredo + Midland/Odessa
    Yup, an 045 or 040 disk will slice them quick.
  5. Likes robert-r liked this post
  6. #4
    Apr 2020
    AntHome 92025
    Thanks, dudes!!! & haha.... there is a grinder with a thin cutoff disc on the bench. Was out there whole time I was driving myself nuts.
  7. #5
    A quick rap with a flat metal bar when resting on the edge of a metal table of bench vice will break it sharply and easily. i use that to knock of dips before sharpening. Yes I've had lots of those.
  8. Likes robert-r liked this post
  9. #6
    Feb 2016
    W. Texas
    I use the edge of the bench grinder wheel to grind a V in the middle then snap it. Then touch up the point.
    Zach
  10. Likes robert-r, Rondo liked this post
  11. #7
    May 2007
    Quote Originally Posted by WTXBTUMOVER View Post
    Zach
    exactly
  12. #8
    A couple pairs of pliers will snap them too.
  13. Likes robert-r liked this post
  14. #9
    When i had to cut a bunch of pieces for short cap torches i would drill a hole in a wood block to the right depth and cut them with a very narrow (.035 x 3") disc on a right angle die grinder, then dump the hot piece in a tray. Didn't take long to cut a bunch up.
  15. Likes robert-r liked this post
  16. #10
    Apr 2020
    AntHome 92025
    Thanks, Everyone!!! Great solutions!!! Very much appreciated.
  17. #11
    Apr 2010
    robert-r
    Quote Originally Posted by robert-r View Post
    Stop thanking - there are many refinements - unposted . . .
    Opus
  18. Dislikes robert-r disliked this post
  19. #12
    Here's a similar method to using pliers I borrowed from a Miller forum.
    I've grown fond of using 2 vice grips, nose to nose for quite some time...snaps 'em nice and easy. I prefer the 8WR's because they "square up" easy due to their width and I usually have a pair with me just about everywhere I tig. The splitting thing doesn't seem to be a problem for me this way.
  20. #13
    Jul 2018
    Cumbria, UK
    You shouldn't snap any tungstens other than thoriated... not great advice IMO!
    Thoriated are the only type that reliably cleanly snap.
    Lanthanated tungstens can often hairline crack when you snap them, and welding with a cracked tungsten is horrible. Ceriated and other types are even worse, they splinter.
    This is common knowledge and something I've seen myself.
    Abrasive wheel is your friend. I use the corner of my diamond wheel to cut through them, you've then got half a prep on the ends straight away as well
  21. #14
    Outside of Raleigh, NC
    exactly
    Me too
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  22. #15
    Nov 2014
    PDX PNW
    Zach
    I just take the extra 2 seconds and cut all the way through so I don’t worry about splintering the tungsten
  23. Likes danielplace liked this post
  24. #16
    Don't cut it -- just grind it back to a point again. I don't know why everybody seems to think new welders need to cut off tungstens. I've never cut a tungsten.
    It's like cutting an inch off a pencil before sharpening it. WTF? Who does that?
  25. #17
    Pensacola , Fla
    he is using a short back cap, must cut
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  26. Likes danielplace liked this post
  27. #18
    Well.
    That's very different, then.
    Never mind!
    Oh -- and, cutoff wheel!
Page generated in 1,713,266,684.95612 seconds with 18 queries
