Page 3 of 8 FirstFirst 12345 ... LastLast
Results 51 to 75 of 200
Thread: Geared head drill press?
  1. #51
    Dec 2014
    Northern California
    Re: Geared head drill press?
    I have had good luck with this one...Amazon has them for a good price too. Well, when I bought it a few years ago...
  2. #52
    Oct 2013
    Long Island, NY
    Quote Originally Posted by Tarmstrong View Post
    Harbor Freight 20" drill also? Thats the press im replacing with this one. Has honestly been and still is a great machine for what it cost me.
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  3. #53
    Aug 2018
    'ta town, KS
    If only I had room and banned for the $10 drill press...
    https://www.gavelroads.com/auctions/...Shop-Equipment
    Mac
  4. #54
    This is probably a stupid question, but I've never had a geared head drill press.
    What happens when you crash it?
    I've, at one time, or other, crashed a tool or two. Maybe break a bit, or something comes loose from the table...……...etc...….. It's no biggee, other than the usual dope slap to my own forehead. Belts slip, and the machine lives to see another day. Always wondered how a geared machine would react.
  5. #55
    Ain't no different than a hand held drill, same type of drive.
  6. Likes MinnesotaDave liked this post
  7. #56
    Aug 2018
    'ta town, KS
    For me gear drives break the bit or whatever is in the chuck... but they always have the power to drill
    Mac
  8. #57
    So, it tears crap up when it stalls/grabs...……...that's great
  9. #58
    Aug 2018
    'ta town, KS
    It doesn't stall...it just spins and breaks...they will hurt you if you are not smart enough to put someone between you and said spinning work piece
    Mac
  10. #59
    Jan 2011
    W. Wisc
    I got a nice keyless chuck from Shars.com for a reasonable price that i really like. Grabs bits like grim death, and very accurate and well turned-out. I think it was like $80 a couple years back?
    Thanks for the info. What size is that press of yours? 20 Ton? 40 ton?
    -Dave
  11. #60
    Oct 2013
    Long Island, NY
    20 tons
    The swag finger break will bend A pretty good length chunk of 1/4
    1/8 it will do the full length.
  12. #61
    I've, at one time, or other, crashed a tool or two. Maybe break a bit, or something comes loose from the table......etc..... It's no biggee, other than the usual dope slap to my own forehead. Belts slip, and the machine lives to see another day. Always wondered how a geared machine would react.
    With a gearhead drill press you ALWAYS have a stop designed into your plan to drill a hole. Weather it is just rotating a long piece around to where it contacts the column of the drill press or having to clamp it down or put it in a vise that is bolted down.
    No doubt they can hurt you but no different than running a gearhead lathe or a radial drill ( that are all gear driven ). Not as dangerous as running a grinder without eye protection and or a guard.
    The secret to not breaking tools is , #1 have a sharp bit, #2 have correct RPM, #3 Use lubricant, #4 do not use more down pressure than is need for a cut. To the dismay of most too little down pressure dulls the bit , too much breaks the tool. More pressure is needed to drill correctly than most people think. If the bit is sharp you should have a nice chip curl coming off the bit. Increase pressure until this happens. If the chips come off in just short little chunks then stop and sharpen the bit. When I drill my cutting oil is smoking heavy from the heat. To the point where sometimes I have to move my head out of the smoke cloud on larger holes. I have to release pressure when drilling to break off the chip then start pressing again.
  13. Likes farmall liked this post
  14. #62
    Jul 2018
    Cumbria, UK
    Not really sure, because I've never crashed a tool... had a few workpieces come loose and broke a few drill bits
    It's the price you pay for having more drilling grunt...
  15. #63
    Jun 2008
    New Plymouth ID
    I didn't get a picture but I was drilling and lost the edge on the start of the cut, harbor freight silver deming drill, heard the noise change and ran over to the drill, by the time I got there I had friction welded the bit to the plate had to take it out of the chuck and wack it with a hammer to break the weld loose. with enough power and reverse it is so nice tapping holes, always straight, not damaging the taps by using an impact. or breaking taps because of the side load of a large tap wrench and a musclehead. drill will litterly tap a 3/4" hole in 1.5" plate at 32 rpm then put it in reverse and back out, all done. i will usually leave a the bit not bottomed in the chuck so if something goes wrong I have time to correct it before breakage. this in a mill or my 3' radial
  16. #64
    Oct 2013
    Long Island, NY
    So in reading the manual for the drill awaiting its arrival, i notice it comes depleted of
    Oil.
    It needs 4.75 quarts of oil, which I’m guessing are not included.
    The manual says use ISO 32 oil.
    I see there is ISO 320 gear oil, which is extremely expensive.
    When i search that, it’s hydraulic oil? Is that correct?
    Zach
    Lincoln 210mp
    Lincoln SW200
  17. #65
    Yes that is correct. You can buy it at most any tractor supply or Fleet farm . It is a medium weight hydraulic oil but is also used for lubricant in gearboxes.
  18. #66
    Oct 2013
    Long Island, NY
    Perfect thanks. Home Depot has it.
    Zach
    Lincoln 210mp
    Lincoln SW200
  19. #67
    ISO 32 is a 10 weight hydraulic oil and shouldn't be too expensive.
  20. #68
    Napa carries it as well. Wouldn't be a bad idea to run it for a half hour or so and dump it and replace. The QC and cleaning is always the greatest on some of the import machines. 5 gallons of hydraulic oil is about 40$ here so it's pretty cheap insurance.
  21. #69
    Oct 2013
    Long Island, NY
    Thanks for the tip, for $10 in oil I’ll probably do that.
    It should be here Friday. I’m not sure if it comes assembled or what, i haven’t a clue how I’m gonna move it.
    I have my current 300 lb press on a grizzly drill press stand with casters hoping i can use it.
    Edit: this thing. Says 1200 lbs so hopefully no issue.
    https://www.grizzly.com/products/Gri...le-Base/T28000
    Zach
    Lincoln 210mp
    Lincoln SW200
  22. #70
    I suggest you completely drain any oil in the machine. Sometimes the machines do come with some oil in them.
    Then, run a magnet around the bottom of the sump. Then completely disassemble the machine to remove the 5lbs of crap ya find in there
    Ya might remember my adventures Winter before last.
  23. #71
    Oct 2013
    Long Island, NY
    https://www.ebay.com/itm/SHARS-7-Pie...YAAOSwjSpeOvWZ
    Would this set of 7 be enough or am i gonna need the interim sizes? There’s a 13 set as well.
    Zach
    Lincoln 210mp
    Lincoln SW200
  24. #72
    I have the 13 piece set and can only think of one time I used a 7/16" one. I don't have a lot of vertical travel and used the 7)16" one to hold a twist drill directly to give me enough space to drill a thick part. For the most part I imagine you will be using a drill chuck anyway. I think I may have used a 3/16" to hold a small end mill as well.
  25. #73
    The 7 pc set will probably do fine . If you need one in between in the future you could buy just the one you need. If you had a milling machine i would say get the 13 pc set.
  26. #74
    Oct 2013
    Long Island, NY
    They have a precision set for $32 and a “high precision” set for $65.
    Should i be worried about high precision? This is from shars.
    Zach
    Lincoln 210mp
    Lincoln SW200
  27. #75
    What are there quoted tolerances? I believe the High precision set is .0005 and the precision one is .0006 If that is the case I would just get the precision set. There again if you had a milling machine I would go to the high precision set.
Page generated in 1,603,564,346.49886 seconds with 13 queries
