Results 1 to 18 of 18
Thread: Retire oxy acetylene hoses due to age
    Jun 2014
    Greenville, Maine
    I just bought a medium-duty homeowner Victor set-up. The hoses are old and stiff. I am thinking about buying a set of Hobart hoses.
    Is there an age at which homeowner hoses should be retired? Does buying the Hobart hoses sound reasonable?
    Thanks,
    Roy
    Airco DIP-PAK 200
    Re: Retire oxy acetylene hoses due to age
    I have used hoses that was over 30 years old.
    I only replace when looks bad, leaks, cut or just tired of longer big hose.
    Quote Originally Posted by irhunter View Post
    Thanks,
    Roy
  3. Likes irhunter liked this post
    Jun 2014
    Greenville, Maine
    Thanks for the reply. The hoses are dated 1997 and are what I'd call somewhat "stiff." No cracking. Probably not used much...stored in a storage locker.
    Airco DIP-PAK 200
    FYI
    Most hobby work size 3/16" x 20-25 foot bottle size 80 to 120 cm.
    When had shop I used 1/4" x 75 feet the due to the bottle was 337 cf.
  6. Likes irhunter liked this post
  7. #5
    Jan 2016
    northeast USA
    Thanks,
    Roy
    new hoses are cheap for the most part, so if they look cracked and stiff replace them and dont think about it and now you know they are new and if cared for have at least 20+ years of trouble free use..that peace of mind is worth every penny spent..
  8. Likes irhunter liked this post
  9. #6
    Jun 2014
    Greenville, Maine
    Copy.
    Airco DIP-PAK 200
  10. #7
    Jun 2014
    Greenville, Maine
    FYI
    Mine are marked 3/16.
    And, I am looking for B-B fittings?
    Airco DIP-PAK 200
  11. #8
    Thanks,
    Roy
    Too bad you are so far away.
    I could give you a set. I have at least two sets brand new on the shelf that came with welding gear I bought. They will prob deteriorate before I need them.
  12. #9
    Jun 2014
    Greenville, Maine
    It's an odd world...likely it would be cheaper for me to buy a new hose, with free shipping, than to pay for shipping on a hose given to me by some kind dude in western Canada.
    Anyone have brand suggestions?
    Airco DIP-PAK 200
  13. #10
    Are the hoses grade R or grade T? Grade T is good for propane and all other fuel gasses but is stiffer than grade R that is only for acetylene. 3/16" hose is OK if you never use big tips or rosebuds very often and your hoses aren't real long.
  14. #11
    Jun 2014
    Greenville, Maine
    They are R. I can't picture using anything other than acetylene for the time being. And, I will be fine with 25' hoses.
    Airco DIP-PAK 200
  15. #12
    Jul 2016
    Midwest
    Hoses are not all created equal. Some are stiff and hard to manipulate, Others are pliable. It's nice to look at the hose prior to owning or you could get the same thing. I've noticed that the hose on a bulk spool is normally pretty flexible.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  16. Likes scsmith42 liked this post
  17. #13
    Jun 2014
    Greenville, Maine
    You mean, you buy it off a bulk spool and they attach the fittings?
    Airco DIP-PAK 200
  18. #14
    I canít see that being economical unless you wanted a custom length. Precut sets are so cheap.
    Best if you are able to check for pliability of hoses though. On line purchases may be hit and miss.
  19. #15
    Outside of Raleigh, NC
    There is a noticeable difference between the cheap, Chinese hoses and higher quality non Chi-com hoses. Iíve seen the Chinese ones dry rot and crack within a couple of years, and they tend to be stiffer.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  20. #16
    Some hose is more flexible but compare apples to apples, ie/ grade R to grade R. Grade T hose is stiffer.
  21. Likes scsmith42 liked this post
  22. #17
    They do make adapters or buy new ends.
    I look on Amazon .
    Note I do not though old ones away you may need some day.
    Today a box full and no longer need buy any.
  23. #18
    Jun 2014
    Greenville, Maine
    Airco DIP-PAK 200
Page generated in 1,603,509,479.61138 seconds with 12 queries
