Results 1 to 25 of 30
Thread: On Off switch for a rotary phase converter
    Fredericksburg, VA
    I have this 3hp Phase -A-Matic RPC I use to run my bigger DoAll upright band saw.
    For now I just plug it into my double headed 50 amp extension cord. Yes, I need to clean that up.
    I have it set up so I have the welder plugged in one side of the cord and RPC in the other. I want to add a switch so the RPC is not running unless I turn it on.
    The coiled up cable in front of the RPC in the last pic gets plugged into the extension cord.
    Eventually I want to rewire part of my panel and just run the RPC straight from the panel. Even if I do that, I dont think it is a good idea to use the breaker as an on/off switch.
    Any ideas on adding a switch?
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Nov 2015
    Re: On Off switch for a rotary phase converter
    I've been using the breaker for years without any problems.
    ESAB emp215ic
    Everlast 250EX / Watercooler
    Victor Cutmaster 42
    Victor Journeyman O/A
    Lincoln Electric Weldanpower 225 AC/DC
  3. Likes Oscar liked this post
    Fredericksburg, VA
    Quote Originally Posted by Smason View Post
    OK. Thanks. I thought that was frowned upon, but if it works, that works for me.
    Millermatic 252 MIG
    Laredo + Midland/Odessa
    Great question and answer, as I'm about to pick up a RPC, but an order of magnitude larger in HP.
  6. #5
    Don't think breakers are intended to be used as on/off switches but whatever. I use fused safety switches like this :
    https://www.homedepot.com/p/Square-D...1NCP/100164967
    Put the proper size fuses in it up to 30 amps. Or go to a larger switch if needed.
    ---Meltedmetal
  7. #6
    Mar 2005
    Under a Rock
    I’ve got this one for sale if it works for you.
    Brand new.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  8. #7
    Mount Tabor VT
    The inspector ready answer includes a manual disconnect within sight or a locking disconnect if out of sight.
    A RPC is a motor. An inspector would require a motor control with overload protection.
    Those in private shops push back at the cost of a proper motor control. It is NOT cheap.
    Most commonly, we are talking about a magnetic contactor with integral overload protection.
    Forever this includes "Heaters" Thermal overload units ordered to match your RPC nameplate. More recently, current transformer units are available. You can adjust amperage.
    These will need a set of control contacts to operate.
  9. Likes scsmith42 liked this post
  10. #8
    Mount Tabor VT
    Brand new.
    I wish you had it in 200 amp.
  11. #9
    Nov 2015
    I never said it was the right way, just that I haven't had any problems. I have a home shop not a commercial shop.
    ESAB emp215ic
    Victor Cutmaster 42
  12. #10
    San Jose, CA Kelseyville, CA
    'ya think?
    CURRENTLY I want to rewire part of my panel and just run the RPC straight from the panel.
    There I fixed it for you.
  13. #11
    Fredericksburg, VA
    Quote Originally Posted by TraditionalToolworks View Post
    'ya think?
    So you have nothing to add? Thanks.
    Millermatic 252 MIG
  14. #12
    Fredericksburg, VA
    Brand new.
    Thanks. Tomorrow I will go out to the shop and check if that will fit my panel.
    Millermatic 252 MIG
  15. #13
    Fredericksburg, VA
    Thanks Willie.
    Millermatic 252 MIG
  16. #14
    Mount Tabor VT
    Thanks Willie.
    I'll put together a package at cost, or part numbers. I'll admit it is pretty rare for people able to fly under the radar to consent to the cost. Most make do switching a breaker Or Ebay knife switch Or a receptacle & cord, replacing occasionally. The overload protection people sometimes live without.
    A bootleg install uses a $40.00 Definite purpose contactor 3 pole, together with a momentary push button station. I'll provide a diagram if you care. This works well, but offers no overload protection.
    A major hazard is loss of limbs. A machine tripps a breaker, then restarts when power is restored might rip off an arm, or head. Magnetic contactor forces you to intentionally restart.
    latest editions of NEC require GFCI protection if plug connected.
  17. #15
    No, there was a hidden message there, but in case you missed it, let me spell it out.
    Don't do what you planned to do, it doesn't sound safe.
    You're current setup doesn't even look safe with wires hanging out of the outlet you have laying on the floor.
    You can do what you like, it's your shop. I wouldn't have that mess in my shop and don't recommend you do either.
  18. #16
    Fredericksburg, VA
    That help would be appreciated.
    I only use the RPC for that saw for now.
    My typical procedure today was turn off the breaker, plug in the RPC, turn on the breaker and that starts the RPC.
    Turn on saw, cut out part, turn off breaker, unplug RPC. Turn on breaker, tack weld or weld part.
    Repeat as necessary.
    Since the parts I am cutting are random shapes for an art project, they all cant be cut at once until the previous piece is in place and I see how it looks.
    I have my Bridgeport hooked up to a VFD and bought the RPC for this saw and some future tools I might get.
    Millermatic 252 MIG
  19. #17
    Soda springs,Id
    If you go the route Willieb laid out you can mount the start stop buttons for the RPC right by start stop switch for the saw. When you later get more machines to run off the RPC you can have the start stop buttons on a cord so you can move it to whichever machine you want to use. Like willie said it will be expensive but will last a long time.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  20. #18
    3 pole ?
    It is single phase feed to rpc.
  21. #19
    Fredericksburg, VA
    Mike
    That sounds like it would be a great way to go. Thanks
    Millermatic 252 MIG
  22. #20
    Mount Tabor VT
    3 pole ?
    Need an extra set of contacts for three conductor control & latching.
  23. #21
    No not really. It is even easier without trying to wire through a separate pole for no reason.
    A simple single phase two pole start/stop latching setup on a contactor has no need for another pole for anything.
    You use one of the ones your already using to hold the coil in.
    Your not using a transformer and low voltage controls. The coil voltage is high voltage same as you are using so you don't need a separate pole for anything.
    Pretty easy to wire using the existing contacts of a two pole contactor. 3 pole is waste of money to buy when you really only need a two pole.
  24. #22
    Fredericksburg, VA
    Oscar,
    Once you get yours set up, can post a pic of what you did?
    Even if it is larger, I still would like to see it to learn.
    Millermatic 252 MIG
  25. #23
    Oscar,
    My stuff isn't code compliant though.
    Daniel, mind if I ask you some questions regarding my RPC when it gets here? I've done my research but I have some lingering inquiries. It's a Southern Phase Converters unit. It's new but I bought it 2nd hand.
  26. #24
    Fredericksburg, VA
    Have you seen what I make and the comment from Traditional??
    I try to do things by code if I can or know how, but am limited by what I know and what I am willing/can afford to pay someone.
    Millermatic 252 MIG
  27. #25
    I hear ya, lol. I'll be glad to share how I end up setting mine up. From the looks of the panel that comes with the system, mine has start/stop buttons so it looks like it will be different from the get-go. I actually like your setup because it looks very portable!
    How about something like this for $16:
    https://www.amazon.com/Corporation-D...3&s=hi&sr=1-16
    With a 60A breaker included, it sure seems heavy duty enough for your RPC.
Page generated in 1,713,258,307.03439 seconds with 18 queries
