Results 1 to 9 of 9
Thread: Victor swivel and lock adapter for cutting torch tip
    I am retired and no longer need this. I was a Millwright and used this several time when I could not get a torch in the right position to cut. It is very handy for someone that gets into tight positions. I have never seen another one of these ever. I do not think they are made anymore. The end swivels 180 degrees and can lock anywhere it is put. It mounts to the end of victor cutting torch or can also be used on a victor machine torch like a track torch . It is probably 40 years old . It is well used but still works as it should. It could probably use some new O rings but it does work the way it is. I can not post picks because my internet is so poor. I can send a picture to a cell phone or and email address with my phone.
    $40 + shipping
    Re: Victor swivel and lock adapter for cutting torch tip
    Interested Gary. Send it in a text to central Wi area code. 3472151.
    MJD ; I sent a pick twice but my phone says it failed to send. This has happened to me before and it did go through. Did you get the pik?
    No, nothing came thru.
    Is it like this. The price listed is crazy but they are available.
    https://pipelinedepot.com/products/c...e-bha-2-victor
    Yes that is it. Mine looks a little different but function is the same. Wow $350 is crazy. $40 is a deal at twice the price
    Ok. It's different than I imagined. I'll have to pass.
    Mar 2015
    I'm interested if you still have it.
    Seattle
    We used to use those at the welding school beveling 1" plate. Used them on an Airco Radiagraph track burner. We would have called that a "bevel tip". They work fine. Lot of brass, probably one of those things that cost a fair bit to make and that has a very tiny market. That's probably why they retail for so much. I see them around, average used price maybe $30-40USD.
    metalmagpie
Page generated in 1,597,425,583.04732 seconds with 11 queries
