Results 1 to 25 of 36
Thread: 56 short hood
    Apr 2020
    56 short hood
    im in the process of tearing my 56 short hood down to restore , and i wanted to start gathering parts , gonna be a while before it gets done , because its farming season now and that takes priority , does any one no the gauge size of the wires that is used for the selector switch and other electrical parts, the length doesn't matter because i'll just buy it in a roll and make my own ends , thanks
    Oct 2013
    cntrl FL
    Re: 56 short hood
    I would just measure the size (gauge) of the old wires from each location that are coming from the generator going to the tap control, so that they will carry the proper amperage. The rest of the smaller wires are 12 gauge.
    SA 200s : 1944 1945 1963 1965 1969 1980
    1981 SA 250 D3.152 DC only
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    Apr 2020
    Re: 56 short hood
    yes , thank you i will , just thought with all the guys rebuilding and restoring sa 200's they would no off the top of there head , thanks
    Apr 2020
    Re: 56 short hood
    i had some time yesterday to rip into the 56, tore it all apart , heres some pictures of it
Size:  182.9 KBName:  IMG_4664.jpg
Size:  179.4 KBName:  IMG_4665.jpg
Size:  252.6 KBName:  IMG_4666.jpg
Size:  152.2 KBName:  IMG_4589.jpg
    Apr 2020
    Re: 56 short hood
Size:  278.1 KBName:  IMG_4607.jpg
    Oct 2013
    cntrl FL
    Re: 56 short hood
    Inside the engine looks pretty clean. The rest of the machine is in good shape. Doesn't look like anyone has been into it .
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
    Apr 2020
    Re: 56 short hood
    either no one has been into it since 1956 or it was redone at one time, but i dont think so, the only problem im having now is trying to free up the one stuck piston, ive put all kinds of liquids down that cylinder to try to free it up , but nothing is moving that piston, i guess ill just take it to the machine shop and let them get it unstuck, other than that , every other item on the welder looks to be pretty good
    Nov 2012
    ROCKVILLE ,,VA
    Re: 56 short hood
    make mixture diesel fuel, acetone and automatic transmission fluid,, she move after soaken !! looks very clean like BYW 200 said me would rehome sleeve put it back together if nothing is wrong with stuck piston
    Apr 2020
    Re: 56 short hood
    i tried every liquid combination known to man , even bought some expensive kroil, i even smacked on the piston to shock it loose, nothing, l'll try a few more things when i have some time ,
    Oct 2013
    cntrl FL
    Re: 56 short hood
    What does the top of the stuck piston look like? Are you trying to turn the crank or knock that particular piston out the top of the block? If turning the crank is hard, it could be something has jammed it somewhere inside the engine or maybe something has got caught on the generator side or flywheel.
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
    Apr 2020
    Re: 56 short hood
    the engine is on an engine stand , no flywhell, nothing inside of motor is jamming it , the older gentleman i bought it from said he bought it off his neighbors kids who left it out with out a cover over the exhaust pipe and water got in and locked the piston up , i tried with a wrench on the front bolt , and tried hammering the piston down , no luck heres some pictures
Size:  278.4 KBName:  IMG_4673.jpg
Size:  314.7 KBName:  IMG_4674.jpg
    Sep 2012
    Wheatland, Wyoming
    Re: 56 short hood
    Take the connecting rod caps off and see if the engine turns. If so get a chunk of 3/4" plate and every day add a pump or so on the potrtapower till it breaks loose.
    Chris
    Auction Addict
  13. Likes MinnesotaDave liked this post
  14. #13
    Apr 2020
    Re: 56 short hood
    i will do that next time i get some freed up time to work on it, maybe this weekend, , i'll definitely post on the progress
  15. #14
    Oct 2019
    Australia
    Re: 56 short hood
    You got the head studs there. Rig up a bar or plate drilled for the studs, put a packer plate between the bar and piston and wind the nuts down. That'll shift it. Hammering will just damage the piston.
  16. Likes MinnesotaDave liked this post
  17. #15
    Apr 2020
    Re: 56 short hood
    maybe i'll try that this weekend if i have some free time, thanks
  18. #16
    Jul 2015
    Re: 56 short hood
    I have a 56 short hood and it has been a great machine. I did have to replace the shunt coils which was a lot of work and I replaced the exciter coils also.
    I had a salesman from Lincoln Electric tell me that Lincoln messed up building those machines because they do not break!
    They are not engineered to fail after so many years.
  19. #17
    Apr 2020
    Re: 56 short hood
    thanks for the info, post a couple of pics of your 56, i still did not get a chance to work any more on it , to many other things to do first ,
  20. #18
    CT
    Re: 56 short hood
    remove the cap on the connecting rod bearing and carefully rotate the crank away from the connecting rod. might be a good idea to put some rubber fuel line on the threads of the connecting rod bolts to protect them and the crank journal. Take a wood 4x4 and shave off the corners till it will fit in 1 of the bores, then use a mallet and the 4x4 to tap the piston down to get it moving. A little torch heat on the cylinder won't hurt either. Just make sure everything else is not stuck, many years ago I snapped a camshaft getting on a crank with a pipe wrench and bar thinking a piston was stuck, it was the valve train that was hanging up. lesson learned.
    "Si Vis Pacem Para Bellum"
    Lincoln Idealarc 250 AC/DC
    Millermatic 251 Syncrowave 300 30A spoolgun
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
    (2) Lincoln Weldanpower 225 CV
    (4) SA200 1 short hood SA250 SAM 400
  21. Likes MinnesotaDave liked this post
  22. #19
    May 2008
    Orange, TX
    Re: 56 short hood
    I'd pull the crank out completely and that way it's totally out of the picture. I've had to press stuck pistons out with my 20T press and the one I have in mind was a bust as it would require sleeves and being outfitted with intake valve seats which these Continentals weren't originally equipped with. Too expensive for what the block is worth.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  23. Likes MinnesotaDave liked this post
  24. #20
    Apr 2020
    Re: 56 short hood
    im gonna try to get to it this weekend, have other things that have to come first, but thats what im going to do is take the crank out completely , and then work on getting the piston or pistons out , might be two that are stuck, we'll see, i'll keep you updated , thanks
  25. #21
    Apr 2020
    Re: 56 short hood
    ok , i got the crank out and three pistons, i put a block of wood on the piston with the angle iron tightened down, it doesnt seem to budge at all , im not gonna force anything. im gonna leave it like this until i can go to the machine shop and see what they can do , that might be a week , when i looked at the bearings on the crank and connecting rods . they were all from the factory, not even scratched up, i bet this motor has barley 300 hours on it , to bad some dumb kids left this machine out in the rain Name:  IMG_4749.jpg
  26. #22
    Re: 56 short hood
    Try putting a 100 watt light bulb in the adjacent cylinder and leaving it while you wait. Did that once on an old IH tractor engine, the heat broke it loose after 4 days of constant pressure.
  27. #23
    Jul 2020
    Re: 56 short hood
    I read once where a welder mechanic would put shop towels soaked with diesel in the cylinder a lite it and let it burn. Says it does wonders for a stuck cylinder. The best penetrating fluid Iíve found 50/50 kerosene or diesel, and automatic transmission fluid. I broke a seized SA200 engine free with it last week. Good luck.
  28. #24
    Apr 2020
    Re: 56 short hood
    i tried all the combinations of fluids known to man to get it unstuck, ive had the pressure with the angle iron on it for a week now , tightening it down some more every other day, its bending the iron, i wonder if i apply some heat to the block with a torch , maybe i'll try that later .
  29. #25
    May 2008
    Orange, TX
    Re: 56 short hood
    Have you tried smackin' it with a big hammer with the pressure still on it?
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,603,801,027.13747 seconds with 13 queries
