Results 1 to 25 of 41
Thread: Belt Grinder Build
    Feb 2016
    Myrtle Beach
    Belt Grinder Build
    I finally had time to start building a new 2x72 belt grinder based on Jeremy Schmidt's plans.
    Started by cutting out most of the pieces.
    Then tack welded the plates around 1 1/2" square bar with shims. Used the press to remove bar and shims.
    Welded the tubes.
    Then aligned everything and welded the hinges on.
    Hopefully I"ll get some more done tomorrow.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  2. Likes Larry4406, Dee_veloper liked this post
  3. #2
    Pensacola , Fla
    Re: Belt Grinder Build
    Great start on a great project, you will be making sparks soon
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Feb 2016
    Myrtle Beach
    Thanks, I got a little more done this evening. Not as much as I wanted to. I am using a different size motor so had to modify the design a little to make sure it was lined up properly.Name:  IMG_5510.jpg
Size:  100.0 KBName:  IMG_5511.jpg
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
    Hell, that looks good.
    When I built the tube bender, I didn't tack it before welding. I welded directly when it was clamped. I had so many stinkin' clamps on the thing that I couldn't see crap when welding. In retrospect, I wish I woulda just tacked it, and saved the trouble.
  6. #5
    Apr 2020
    How did you cut your plate parts? Bandsaw? Did you just glue full size printouts of the plans on the steel and brute force it?
  7. #6
    Pensacola , Fla
    Find a CNC plasma to cut the parts, a small amount of clean up and you done.
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  8. #7
    Feb 2016
    Myrtle Beach
    Thanks!, I had clamps everywhere too when tacking then eliminated what clamps I could to weld it out.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  9. #8
    Feb 2016
    Myrtle Beach
    Quote Originally Posted by Larry4406 View Post
    I actually printed the diagrams on to full sheet adhesive backed shipping labels then cut them out, stuck them on the metal, and cut out with a band saw. Some of the metal I used was scrap from other projects and was rusty so I put them all in the blasting cabinet and cleaned them up after cutting to remove rust and mill scale. Getting the pieces prepped was definetly the most time consuming part.
    Although acourtjester is right it would have been a lot easier to have them cut but I didn't mind cutting them.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  10. #9
    Oct 2018
    I'm not sure what is taking you so long.
    Kidding of course! You are moving fast!
    What are you using for a motor?
  11. #10
    Feb 2016
    Myrtle Beach
    Quote Originally Posted by jh1990 View Post
    Thanks heres a pic of the data plate on the motor I'm using. I have had it for a couple years waiting for somethimg to use it on.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  12. #11
    Feb 2016
    Myrtle Beach
    A few more pics. Got the Platten basicaly done and the contact wheel holder almost finished. Also built a stand for it.
Size:  81.8 KBName:  IMG_5534.jpg
Size:  106.6 KBAttachment 1711478Attachment 1711479Name:  IMG_5548.jpg
Size:  109.1 KBName:  IMG_5559.jpg
Size:  105.4 KBName:  IMG_5560.jpg
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  13. #12
    Oct 2018
    [QUOTE=Capt B;8748980]A few more pics. Got the Platten basicaly done and the contact wheel holder almost finished. Also built a stand for it.
    Looks really nice. You are very skilled.
    Do you have a VFD picked out?
  14. #13
    Feb 2016
    Myrtle Beach
    [QUOTE=jh1990;8749131]
    Quote Originally Posted by Capt B View Post
    Thanks, I have one that I got with the motor can't remember the brand. I'll look tomorrow. I finished today except for wiring and painting but was in a hurry and didn't take any pics I will take some tomorrow when I wire it and look at the VFD specs.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  15. #14
    Apr 2020
    The motor's weight appears to be eccentric relative to the rotation shaft. Is there any attempt to counter balance this design or the eccentric weight is negligible?
  16. #15
    Feb 2016
    Myrtle Beach
    It's negligible when everything is together it's pretty easy to adjust and is rock solid when running.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  17. #16
    Feb 2016
    Myrtle Beach
    Still need to paint, build a small wheel attachment and radius attachment. But it runs great and tracks perfectly.
Size:  86.5 KBName:  IMG_5625.jpg
Size:  118.5 KBName:  IMG_5634.jpg
Size:  140.0 KBName:  IMG_5636.jpg
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  18. #17
    Feb 2016
    Myrtle Beach
Size:  130.8 KBName:  IMG_5609.jpg
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  19. Likes psacustomcreations liked this post
  20. #18
    May 2016
    Southern California
    That looks excellent! Thanks for all the pictures, I like the flat face vs radius wheel option. I was puzzling over the tool rest, seeing the vertical and angle adjustment clearly. I just didn't see keeping it centered on the belt. Especially as the belt orientation changes from vertical to horizontal. I like how the geometry maintains center in both positions with either the radius wheel or flat face belt. I think the secret is position of the bottom wheel of the flat face compared to the radius wheel. Appreciate you sharing this build.
    Miller Multimatic 220AC
    Miller Thunderbolt 225
    Victor OA
  21. #19
    Feb 2016
    Myrtle Beach
    Quote Originally Posted by _Dom View Post
    Thanks and You're welcome! The belts always track centered on the hinge bolt and as long as the height of the attachment is where it should be it will stay centered.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  22. #20
    Apr 2020
    Nice build.
    Where did your source your drive and driven wheels?
  23. #21
    Feb 2016
    Myrtle Beach
    Nice build.
    Thanks, https://www.knifegrinderparts.com I think I am going to order the small contact wheels from them as well.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  24. #22
    Dec 2014
    Northern California
    Great build...
    Could you give some info on that control fir the motor please...I need to get a motor and Control for speed adjustment for mine...
  25. #23
    Feb 2016
    Myrtle Beach
    Quote Originally Posted by Tarmstrong View Post
    Great build...
    Your grinder looks good as well. Unfortunately, I took the VFD I have apart years ago when I was using it for another tool and put it in a weatherproof case so I can't find a model number on it. It is a cheapo from eBay the only issue was it had a cooling fan that could suck metal shavings into it. That's why I put it in the case. I attached a pic of the front.
    Is your motor single phase or 3 phase?
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  26. #24
    Dec 2014
    Northern California
    Single...so I need a new motor...
    Unless you know some magic to make a single into a variable.
  27. #25
    Feb 2016
    Myrtle Beach
    I believe they do make single-phase output VFDs but I don't know enough about them to say for sure they would work with your motor. I am definitely not an expert on motors. I found my motor used on craigslist years ago and think the VFD was only 150 or so on eBay. Just have to get a VFD capable of at least the motors HP.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
Page generated in 1,594,904,701.71328 seconds with 13 queries
