Results 1 to 25 of 41
Thread: What can you do with pieces of filler rod?
    Mar 2009
    Northern Virginia
    too bad there wasnt a device to join these pieces together.
    Jan 2016
    northeast USA
    Re: What can you do with pieces of filler rod?
    other than filling in gaps with them to weld over..not much..how long are the pieces your talking about? usually I can get them down to a few inches .....im thinking if you can make a jig with a small clamp you can use them up to 3/4 to 1 inch pieces...
    almost like a refillable pencil or even a soap stone holder but able to hold thinner rods..to hold in your hand to feed the smaller pieces as you weld...
    Jun 2008
    I usually tack it to the next piece...............Mike
    Mar 2009
    Northern Virginia
    The person who invents a device that joins your pieces Of filler rod will get rich.
    Sebeka and Bemidji MN
    Quote Originally Posted by vdotmatrix View Post
    Some people call it a tig welder....
    Airco 300 - Syncro 350
  6. Dislikes vdotmatrix disliked this post
  7. #6
    Soda springs,Id
    Don't have a tig but be it brass or iron I weld the new to the stub that's stuck in the puddle with my O/A torch and carry on.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  8. #7
    Oct 2016
    I keep a pair of curved hemostats handy, helps to use up short pieces of brazing rod, and also lets you feed from different directions on small things.
  9. #8
    Jun 2009
    Draper, UT
    other than filling in gaps with them to weld over.....
    I was doing this the other day and spent 5 minutes trying to get it to work...
    Eventually realized that the short piece of filler I picked up and was trying to weld into the gap was actually a piece of tungsten
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
  10. #9
    Mar 2017
    Forest Grove OR
    I've found their rather small size makes them fit rather nicely in my garbage can.
    Everlast 350 EXT - Thermal Dynamics Cutmaster 52 - Rogue Fabrication M600 xHD tube bender
    Milwaukee 4208 Mag Drill - Shopmaster Eldorado Combo mill/lathe machine with DRO.
  11. #10
    Put the last bit of filler in the oxy/acetylene drill bit holder for that style tip cleaner. It will allow you to use them down to 1/2" if you wanted.
    Good for up to 1/16" filler but could modify to fit larger easily.
    I do not mess with the shorts but this would get them down really short easily.
    Usually if you have filler your doing oxy/acetylene or tig so just tack them if you want to use every inch.
  12. Likes vdotmatrix, Dee_veloper liked this post
  13. #11
    San Jose, CA Kelseyville, CA
    I seriously think you're overthinking this...is it really worth the time and money?
    Next will be joining small pieces of tungsten...
    EDIT: in fact here's something I would wager a guess on...it would be cheaper to recycle and melt down both filler and tungsten and re manufacture new.
  14. #12
    Mar 2005
    Under a Rock
    what can you do with pieces of filler rod.
    I feed mine to my dog.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  15. #13
    Quote Originally Posted by TraditionalToolworks View Post
    I think he was being sarcastic.
    Hint: A "device that joins your pieces of filler wire" = a WELDER
  16. #14
    I can only hope you're correct, but I don't think so from some of his other posts. He posted a similar question on another welding forum, trying to find out what the melting point is on filler. Sounds like he's trying to figure out a way to stick it together.
    Indeed.
  17. #15
    Soda springs,Id
    Do you mean welder or weldor?
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  18. #16
    Mar 2009
    Northern Virginia
    Nothing wrong exploring different avenues. Who knows?
    Indeed.
  19. #17
    Mar 2009
    Northern Virginia
    i don't limit what i can learn or figure out. Time and money not the issue and i am not saying i will invent something just trying to see whats out there....thanks for responding.
  20. #18
    Aug 2019
    northeastern PA.
    find your self a "pin vice", usually get one in a hobby store and they have different size collets in them. I use one because of my "asbestos" fingers. They see too much sunlight and they burn.
  21. #19
    I'm certainly not trying to convince you one way or the other. From a sensible standpoint you end up with about 3"-4" from a 36" length of filler, so it's about 10%. If you think about 10% of the cost of what the filler actually costs, I think you'll start to see that it really doesn't make sense.
    However, if you could get enough of it, it might be recyclable. I don't know if the outer coating would prevent it from easily being able to melt down to recycle without cleaning.
    Most people will continue to toss out the last few inches, kinda like pop cans. People are lazy in general, I hate to say.
    No matter what, I think the difficult part is going to be getting anyone to collect the waste, it needs to be compelling.
  22. #20
    I'm still trying to figure out how to splice that last 15' of mig wire on the new roll.🤣
  23. #21
    You can save them. When you burn you last rod on Saturday night, suddenly a 4 inch stub is not so useless. The also work as shims for centering item inside tubing prior to welding. You can twist the to make jewelry, clips, key rings or hooks for holding tools. Twisting adds strength. You can mock up a spiral stair and use them as balusters.
  24. Likes vdotmatrix liked this post
  25. #22
    Oh,I am currently modding a stop on my iron worker. It appears I used filler wire to attach / hook the spring. I made the stop a few years ago, deficiencies arose today.
  26. Likes vdotmatrix liked this post
  27. #23
    Mar 2009
    Northern Virginia
    Quote Originally Posted by BillE.Dee View Post
    I like that is pretty cool! I will check it out.
  28. #24
    Post # 10.
    That is what the oxy/acetylene tip cleaners use. Pin Vise.
  29. Likes vdotmatrix liked this post
  30. #25
    Mount Tabor VT
    His ears are straightening out!
Page generated in 1,594,256,718.67841 seconds with 12 queries
