Results 1 to 8 of 8
Thread: Lincoln Electric SP135 PLUS
    Help help
    Troubleshooting lincoln electric sp135 plus voltage loss when trying to weld.
    I have welding voltage at 18 -29 v at torch wire feeds fine when trigger is pressed, I lose voltage ( goes to 0 ) when I touch the work. when I let trigger go voltage goes back to welding volts.
    I'm lost. I hope someone out there can help. Oh I have no welding voltage at tip and wire unless trigger is pressed
    Feb 2012
    Re: Lincoln Electric SP135 PLUS
    Do you have good power going to machine? Is it on an extension cord? Is the ground/work clamp making a good connection?
    Mar 2005
    Under a Rock
    curious
    are you running flux or solid wire?
    is the polarity correct and the lugs tight?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Thanks for responding Insaneride,
    Yes I have 120 AC volts to Outlet, Mig plugged in directly to outlet, I strike wire to the work clamp itself with same results. It sparks and a little burn back and welding voltage drops to 0. I lift wire of work clamp voltage goes to welding voltage asper desired setting.
    Yes Polarity is correct and I am using flux core wire
    Thanks John Lug are tight as well. I did notice the Lugs have a nut under the lead then a wing nut to secure the lead to lug.
    THANKS 131re, I had the volt meter on the Lugs alone, then to the leads, one on tip and one on work clap. I reads the same voltsge at both location at any desired volt setting. Once I touch the work (under a load) the voltage drops to 0, Wire feeds as it should and continues even when the voltage drops.
    I'll try your test tomorrow and let you know.
    UPDATE replaced torch cable and it welds like new.
    After spending hours and hours days and days tests and tests it turns out it was frayed wire in torch cable.
Page generated in 1,603,621,780.84395 seconds with 11 queries
