Results 1 to 7 of 7
Thread: Roughneck 1E no power output need help
    texas
    i have a roughneck 1e that has been sitting 5 years. i have it running but am getting no ac or welding output. is there anyone near Waco, tx that works on these. thanks
    Re: Roughneck 1E no power output need help
    Quote Originally Posted by hoghead52 View Post
    Its been a long time ago but I had a 1E that did not produce power or an arc. I purchased it for $150 about 30 years ago. All I did was remove the sheet metal and I found a wire shorted to the case where the insulation wore through from vibration. I owned that welder for about 15 years and then sold it for $600.
    texas
    i am still needing someone close to Waco to work on my roughneck. thanks
    I had the same issue on a 1e. Check the weld power switches. If they are functional test the diodes on the circuit board. I replaced a couple bad diodes and it was good to go.
  5. Likes hoghead52 liked this post
  6. #5
    Feb 2013
    Ask your local welding supply. I know one in north zulch Tx but I’m not sure about Waco.
  7. #6
    texas
    great idea thanks
  8. #7
    The Roughneck welders have slip rings.
    Since bend sitting 5 years the rings will have oxide and this will give no power.
    Simple to clean slip rings with 120 to 200 grit paper.
Page generated in 1,713,288,167.17100 seconds with 18 queries
