Results 1 to 9 of 9
Thread: Brazing metals question
    Oct 2012
    I’m familiar with brazing steel, using bronze. I’ve done a lot of soldering with copper. What I want to figure out now is attaching brass. Should I do this with silver solder only? Will bronze rod work on it?
    Jun 2011
    Aiken SC area
    Re: Brazing metals question
    Silver solder works for me. Bob
    I typically use silver, brass to steel.
    I have used bronze on welding my brass to bass for a tig welding lug.
    Sent from my LGLS775 using Tapatalk
    May 2010
    Ct.
    I’ve brazed both copper and brass. I was originally
    concerned that I might reach the melting point of
    the base metals but have never had a problem.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Sep 2015
    West coast of Florida
    Attaching brass to...steel?
    Either way look at this page from Harris and select the metals you want to join for the correct filler and flux
    Harris brazing
    Richard
    Website
    Brazing rods can be brass or bronze. Some are called bronze but are actually brass. A lot of times they are interchangeable but your question is confusing. If you're joining brass to brass, silver solder could be a good option.
    Feb 2012
    Sweden
    Copper alloys are called bronzes, so brass is actually a specific type of bronze.
    Brass and bronze can be brazed, but as the base metal can have close to the same melting point as the filler there may or may not be problems with the base metal melting - if it does you're technically welding, not brazing. Using a lower temperature filler such as silver brazing rods may be the easiest option, but I don't think there are any hard wrongs or rights. Go with what works for you.
    Quote Originally Posted by G-son View Post
    Never heard that before. My understanding is that bronzes are copper alloys that contain tin, and brasses are copper alloys that contain zinc.
    Oct 2012
    Harris brazing
    It’s to attach brass to brass.
Page generated in 1,713,279,641.89543 seconds with 17 queries
