Results 1 to 25 of 33
Thread: Commercial Tree Stand Repair
    Mar 2014
    Troy MI
    I didn't realize that a commercial Christmas tree stand could cost $472. Figure 1 below shows a typical one.
    1. Commercial Tree Stand
    Name:  1. Commercial Tree Stand.jpg
    One of the engineers that I work with dropped off an heavy duty Christmas tree stand to be repaired. Originally it had 4x 1/2"-13 UNC PEM type nuts pressed into tabs that held screws that contacted the tree as shown below. Two of the four PEM nuts had pulled out.
    2. Broken Tree Stand
    Name:  2. Broken Tree Stand.jpg
    3. PEM Threaded insert
    Name:  3. PEM Threaded insert.jpg
    My friend had replaced the missing PEM nut with two nuts as shown below.
    4. Nut to replace missing insert
    Name:  4. Nut to replace missing insert.jpg
    The tab that supported the PEM nut was kind of wimpy as shown below.
    5. Not much metal on tab
    Name:  5. Not much metal on tab.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
  2. Likes ronsii liked this post
  3. #2
    Mar 2014
    Troy MI
    Re: Commercial Tree Stand Repair
    Some of the tabs were bent right at the hole instead of the base of the tab.
    6. Bent tab
    Name:  6. Bent tab.jpg
    The other problem was that the base of spike that supported the tree was cracked where it was attached to the water pan.
    7. Crack at base of spike
    Name:  7. Crack at base of spike.jpg
    After I removed the spike from the pan, I found that there was a cold lap joint on the weld that attached the spike to the pan. The rusty metal in the next two pictures show that there was large areas of the weld with no penetration.
    8. Cold lap on weld-1
    Name:  8. Cold lap on weld-1.jpg
    9. Cold lap on Weld-2
    Name:  9. Cold lap on Weld-2.jpg
    This defective weld also minimized the foot print supporting the spike, The minimum foot print in conjunction with the damaged PEM nuts caused a moment on the base of the spike that cracked the bottom of the pan as shown below. This is a problem because it would cause the tree water to leak out of the pan.
    10. Bottom of stand
    Name:  10. Bottom of stand.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  5. #3
    Mar 2014
    Troy MI
    11. Crack on bottom near spike
    Name:  11. Crack on bottom near spike.jpg
    I cut out a disk to beef up the area where the spike attaches to the pan.
    12. Cutting disk
    Name:  12. Cutting disk.jpg
    13. Disk cut
    Name:  13. Disk cut.jpg
    I TIG plug welded the spike to the disk as shown below and then fillet welded the top of the spike to the disk on the other side (not shown in this picture)
    14. Spike plug welded
    Name:  14. Spike plug welded.jpg
    Next I MIG welded the spike/disk assembly to the bottom of the pan as shown below.
    15. Spike replaced-1
    Name:  15. Spike replaced-1.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  6. Likes ronsii liked this post
  7. #4
    Mar 2014
    Troy MI
    16. Spike replaced-2
    Name:  16. Spike replaced-2.jpg
    I also TIG welded the spike to the bottom of the original pan.
    17. Spike welded to top-1
    Name:  17. Spike welded to top-1.jpg
    18. Spike welded to top-2
    Name:  18. Spike welded to top-2.jpg
    I decided to remove the wimpy tabs and replace them with thicker wider tabs. Notice the fill-in weld shown in the upper left hand view. (You have to work with the geometry that you are dealt.)
    19. SolidWorks drawing of new tab
    Name:  19. SolidWorks drawing of new tab.jpg
    I tap drilled the tabs for 1/2"-13 UNC threads. I wanted to orient the flats of the nut parallel to the chamfer so I made a threaded arbor to align the tap drilled hole in the tab with the threaded hole in the nut.
    20. Nut alignment arbor
    Name:  20. Nut alignment arbor.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  8. Likes ronsii liked this post
  9. #5
    Mar 2014
    Troy MI
    Next I TIG welded the nut to the tab.
    21. Nut in place for welding
    Name:  21. Nut in place for welding.jpg
    22. Nut TIG welded
    Name:  22. Nut TIG welded.jpg
    Then I ran a 1/2"-13 UNC tap thru the nut and tapped the tab as shown below.
    23. Tab tapped
    Name:  23. Tab tapped.jpg
    24. Tab - nut asm done
    Name:  24. Tab - nut asm done.jpg
    Next I cut off the four tabs.
    25. Old tab cut off
    Name:  25. Old tab cut off.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  10. Likes ronsii liked this post
  11. #6
    Mar 2014
    Troy MI
    Then I clamped the new tab/nut assembly in place.
    26. New tab clamped in place
    Name:  26. New tab clamped in place.jpg
    Finally I TIG welded the tabs to the base.
    27. Weld on bottom of brace
    Name:  27. Weld on bottom of brace.jpg
    28. Top weld on tab
    Name:  28. Top weld on tab.jpg
    29. Bottom Weld on tab
    Name:  29. Bottom Weld on tab.jpg
    And here it is all done except for painting.
    30. Tabs all welded
    Name:  30. Tabs all welded.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. #7
    Nice job as always!!!! You certainly put plenty of top quality workmanship into your repairs
  14. #8
    Mar 2014
    Troy MI
    Last but not least I painted it.
    31.Bottom Painted
    Name:  31.Bottom Painted.jpg
    32. Top Painted
    Name:  32. Top Painted.jpg
    33. All Done
    Name:  33. All Done.jpg
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  15. Likes ronsii liked this post
  16. #9
    Mar 2014
    Troy MI
    Thanks, I like to always fix the root cause of the problem in addition to the welding.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  17. Likes ronsii liked this post
  18. #10
    Jun 2011
    Aiken SC area
    Some gussets welded to your modification going to the legs would give your tabs some support when the screws are against the tree. A little pressure from the screws will bend your tabs. Bob
  19. Likes Dee_veloper liked this post
  20. #11
    Dec 2015
    Quote Originally Posted by rhunt View Post
    I agree, the weight of a large tree leaning in any direction will bend those tabs.
  21. #12
    Nice mod.
  22. #13
    Southern California
    Crazy price for a IMO ugly and weak stand... gives me hope! haha
    Pretty involved fix, and though very well done I (like others) think those tabs will also bend with the forces involved.
    My advice for a fix would be either
    A ring of thicker material welded to the top, or ring reinforcing existing material with stitch welds tied into legs - with nuts attached to thicker portion (might need load spreading washer/backer depending on strength of ring),
    Or You could also attach thicker flat bar that runs all the way down the tube (tying into the legs) - essentially extending the thick tabs to to the base of the stand.
    If your fix works in the long run I was wrong and owe you a beer though! Like I said, it was well done though I think the design was wrong.
  23. #14
    Quote Originally Posted by Don52 View Post
    -Don
    Very nice work!!! It's at least a couple times stronger than stock
  24. #15
    Apr 2010
    Don52
    a heavy duty Christmas tree stand to be repaired.
    'The engineer' - what field? . . . and who build the
    original-miscarriage . . . ?
    Opus
  25. #16
    I have the cat to test xmas tree stands. He may look dumb, but that's just a disguise. Name:  20200327_171618.jpg
  27. #17
    Lol!!! Yeah I've seen a few 12 pound kitties go climbing before.
  28. #18
    This guy is closer to 21. We call him the O'beastie. He loves to open UPS packages.
  29. Likes ronsii liked this post
  30. #19
    Oct 2013
    Ohio
    Poorly engineered stand.....Nice repair on a piece of junk.
  31. Likes snowbird liked this post
  32. #20
    Dec 2016
    Make you wonder if it would be cheaper to build from original parts instead of modifying/fixing the broken design.
  33. Likes tapwelder liked this post
  34. #21
    Feb 2009
    Central CA
    Quote Originally Posted by robson1015 View Post
    It's an age-old problem. The cost of the repair would have gone a long way toward the purchase of a new stand. But then he'd have a new, poorly designed stand that is sure to fail in the same way eventually. So repair and modify the old one so it lasts a bit longer this time around. Anyway, I always enjoy seeing how people do these sorts of things--I'm only a hobby welder so I have a lot to learn.
    Tim
  35. #22
    Mar 2014
    Troy MI
    Several people suggested additional steps that could be taken to prevent the tabs from bending. I always enjoy brainstorming with competent mechanics. I agree that any of these approaches would have made it much more robust. If it were my stand I would have incorporated one of these enhancements.
    Quote Originally Posted by Dee_veloper View Post
    The customer just asked me to weld on four nuts, because two of the four PEM nuts fell off. After examining the stand I noticed a few things wrong.
    1. The tabs were bent in the middle.
    2. There was very little metal left around the hole to weld on the new nut.
    3. The tree spike was cracked on the bottom.
    4. There was a crack through the bottom, which would cause the tree water to leak out on the floor.
    I ran the additional cost to repair the obvious problems by my customer and he agreed to cover it.
    My customer owned the stand for 5 years and the base of tabs were not bent (as you can see in slide 17).
    He must have been careful with the stand, because a screw gives you more than enough leverage to bend the tabs.
    Quote Originally Posted by timrb View Post
    Tim
    I encountered the classic problem; How far to go on a repair.
    Thank you for all of your comments.
    It makes the thread much more interesting
    If my customer had a cat like O'beastie, he would definitely require the suggested enhancements.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  36. #23
    Looks about as good as a guy can do with what's at hand. Good job.
    Issue ain't the tabs...……………...wrong to focus on the tabs as the weakness. It's the material the tabs are connected to that poses the issue. The thin pipe is just that...…..thin pipe. It'll bend before the tabs do...……..can't do a thing about it, unless you literally redesign the crazy thing.
  37. #24
    Best suggestion so far....a piece flat extending to base of pipe incorporating the bolt thingy. You spread the load all over that thin wall crap. I think ShowBlues got it right
  38. #25
    Apr 2013
    test post
Page generated in 1,594,618,578.75237 seconds with 13 queries
