Results 1 to 10 of 10
Thread: Lincwelder 225 with Onan issues
    Looking for some advice on my Onan powered Welder/Generator.
    Fires up good and idles down within 30 sec. It throttles up as soon as I strike an arc; and the first rod runs pretty good but when I start the second rod the engine starts to lose power and struggles to maintain rpms eventually stalling out.
    I pulled the Marvel Schebler carb, stripped it down and soaked it in Carb cleaner overnight, cleaned and reinstalled, but it does the exact same thing as it did before...any ideas?
    Onan model # is CCKA-S/2976J
    Welder model # DC-225/3-AS
    ct.
    Re: Lincwelder 225 with Onan issues
    Sounds like fuel bowl isn’t filling fast enough for engine to run
    sustained at high rpm. Maybe blow out carb passages with brake
    cleaner and make sure line from tank is clear?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Soda springs,Id
    Have you checked the fuel filter if it has one? How about the fuel pump?
    Mike
    Hobart G-213 portable
    Dec 2003
    Fairfield,CT
    I just got one of these running that sat for 10 years with fuel in it. Same prob. I took the carb apart twice. I missed the little tiny brass jet in the carb. I also knocked off the plastic fuel mixture adjuster lever and reset the mixture with a screw driver and not the stupid lever.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    This has two jet adjustments, one is a float stop which has a tee grip and the other must be mixture, which has a slot for screw driver. Thanks for the info
    Welcome! Lacquer thinner is excellent for carburetors that have been sitting, also a set of torch tip cleaners and a set of number drill bits with a pin vise. I recently did the carb on a Yamaha 4 wheeler this way, I also have a set of small needle tips for a blow gun that I use.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    Soda springs,Id
    These can usually be found at a welding supply. They range from small to very small.
    Mike
    Thanks Mike, it was the fuel pump. Can you help me with the carb settings?
    Soda springs,Id
    It's been awhile but IIRC the only adjustment is the idle mixture and idle speed.
    Mike
    Dec 2003
    Fairfield,CT
    It is more of a graceful dance of feel and hear between the mixture and idle screws. I get them to where I adjust the mixture to get the highest idle then I adjust the idle. I keep toggling back and forth till I get to where I want to be. Also, make sure when you flip it to high run that it does not stumble getting there. If it does you need to adjust a little more enrichment into it. Then you have to go back to step one for the idle and mixture. It is more of an art.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
Page generated in 1,593,878,001.56573 seconds with 12 queries
