Results 1 to 13 of 13
Thread: Ntm
    Colorado Springs
    Ntm
    I picked this up from the ARC thrift store the other day. It a Ryobi 12" drill press and at $69.00 I thought it was a good deal. The spindle is tight and there's no wobble in it. The only problem is that it has some surface rust on the table and column that I need to clean up. Any ideas on the best way to do that? This had to come from somewhere else because we don't have rust like this in Colorado.
    Sent from my XT1635-01 using Tapatalk
    Lincoln 175
    Monkey Wards 230v. Stick
    Oct 2019
    Australia
    Re: Ntm
    wire wheel then spray with enox and allow to dry. Leaves a coating that protects against further rust.
    Colorado Springs
    Re: Ntm
    Thank you. Where do you get enox?
    Lincoln 175
    Jan 2016
    northeast USA
    Re: Ntm
    corrosion x much better than enox...a little goes along way..look it up on you tube and youll be amazed how good it is, great for firearms too..
    https://www.amazon.com/Corrosion-X-9...s%2C182&sr=8-1
    Oct 2019
    Australia
    Re: Ntm
    Any engineers supplies, hardware store etc will have enox. Haven't seen corrosion x in Oz so don't know about it. I've had very good results with enox.
    Dec 2008
    Re: Ntm
    You don't need any fancy chemicals.
    600 grit sandpaper and car wax is your friend.
  7. Likes HotRodTroy liked this post
  8. #7
    Dec 2009
    Re: Ntm
    For the flat surfaces try a single edge razor blade dry. It will remove the bulk of it, then finish up with Scotchbright, 600 paper, etc. using lubricant like WD-40.
  9. Likes Dee_veloper liked this post
  10. #8
    Colorado Springs
    Re: Ntm
    Thanks for the ideas and suggestions. I prefer the least cost an more elbow grease options.
    Lincoln 175
  11. #9
    San Jose, CA Kelseyville, CA
    Re: Ntm
    How about some good 'ol diesel and some 600 grit wet/dry ?
    Diesel is easy on your hands, many people don't know you can actually wash your hands in it. As a bonus it leaves some lubrication in the metal to prevent rust in the future.
    That said, I like to use T-9 in my shop for rust preventative, it's not designed to remove rust however.
    Edit: I should add, Boeshield has a product called RustFree that does remove rust, but I think too many products confuses the issue. You can get diesel at just about any gas station, or kerosene will work the same.
    Last edited by TraditionalToolworks; 06-20-2020 at 07:26 PM. Reason: Add comment about RustFree
  12. #10
    Mar 2005
    Under a Rock
    Re: Ntm
    Too much thought going into a simple task.... just hit it with some scotchbrite or fine sand paper and call it a day. maybe a spritz of WD on a paper towel... DONE.
    that drill press looks almost identical to my Craftsman cept mine has a square table.
    A small drill press vice comes in handy also.
    Name:  Annotation 2020-06-21 083454.jpg
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  13. #11
    Colorado Springs
    Re: Ntm
    I have the vice but I'm considering getting a cross-slide to go with it.
    Lincoln 175
  14. #12
    Arizona
    Re: Ntm
    Citric Acid
    Non-toxic, very little elbow grease, and works pretty good on horseshoes too:
    Yeswelder MIG-205DS
  15. #13
    Re: Ntm
    Being the clod I usually am...........rust like that, even on a machine table, gets the cup brush treatment. NOT A HONKIN' WELDING CUP BRUSH Just a bronze/brass leetle cup brush in a die grinder. Takes the crud off without digging into the soft iron.
    Then slather a little hydraulic oil on your hands, and caress the metal Not where it's drippin' off your pudgy lil' fingers........just so the skin is coated with a light bit of oil, then smoogie it around with a rag that has the same oil on it. Don't believe me..............just try wiping hydraulic oil offa anything without some solvent I even get the stuff on my dog when I work with it!!
Page generated in 1,713,294,138.29584 seconds with 19 queries
