Results 1 to 13 of 13
Thread: Where to buy solvent resistant orings
    Arizona
    This valve is out of my AC flush bottle blow gun, it sticks real bad, won't return at all and I figure the oring must be swelled. Where do I get some good orings that will hold up to solvents? Not sure what to look for, Viton?
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    Jan 2016
    northeast USA
    Re: Where to buy solvent resistant orings
    nitrile o rings seem to hold up good..amazon has a nice supply of them
    You'll find nitrile o rings used in many applications, including where oil resistance is needed or where low temperature functionality is required. ... This material has an excellent tolerance for high temperatures, resistance to oils, fuels and hydraulic fluids as well as aromatics and solvents.Oct 31, 2018
    Viton vs Nitrile o-Rings: What Are The Differences? | NES
    this link explains the 2 and which is better for what applications..
    https://www.google.com/url?sa=t&rct=...ha0ZOrwTyb4cuk
    Dec 2011
    Tampa FL
    What is the solvent you are using?
    Mike
    Arizona
    Originally I used it with AC flush solvents but more recently I have used it for kerosene and brake parts cleaner. It is over 20 years old so I can't complain. I don't really do AC work any more but the bottle is very handy for cleaning a lot of things including the tubing I use to draw oil samples.
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Dec 2008
    Your local diesel injection shop will have what you need.
    They have orings by the 10,000snds!
    May 2012
    Ontario, Canada
    If you're in the usa it's impossible to beat McMaster Carr
    I'd try viton, they are
    Sep 2011
    Jasper TX
    When to choose Buna or Viton Elastomer
    Posted on December 12, 2012
    The choice of elastomers, rubber parts, in a pump can be very critical to the long-term success of the pump system. Pumptec provides 2 standard choices for their pumps, Buna or Viton.
    Buna (NBR, Nitrile) is standard in most pumps and works well in most uses in cleaning and fluid pressurizing applications. This form of synthetic rubber is generally resistant to oil, fuel, and other chemicals (the more nitrile within the polymer, the higher the resistance to oils but the lower the flexibility of the material). Buna o-rings are black.
    Viton is a brand of synthetic rubber and fluoropolymer elastomer commonly used in O-rings and other molded extruded goods. It is a trademark of DuPont. Pumptec uses Viton in pumps used in Pest and Lawn spraying because of its resistance to hydrocarbons found in some chemicals. Viton o-rings are brown.
    Owner of Fast Leroy's Bar and Grill
    Liquor up Front, Poker in the Rear
    Sep 2014
    I believe you would want Viton O-rings. Not sure where to get them though. If the walls are scratched badly I would not recommend Viton though. I used to use them in centrifuge pumps that ran hazardous material through them. They held up well.
    Sincerely,
    William McCormick
    Sep 2014
    Grainger has Viton O-rings. The prices seem fine.
    Sincerely,
    William McCormick
    Dec 2011
    Tampa FL
    Best choice for brake parts cleaner, based on the ingredients in CRC Brakekleen , would be Perfluoroelastomer compound FFKM. this is going to be expensive, as far as orings go and more difficult to find. 2nd choice would be Viton Extreme compound ETP also difficult to find. Third and most practical choice would be Viton FKM. There are multiple online sources for all of these.
    Mike
  11. Likes 12345678910 liked this post
  12. #11
    Arizona
    So I took the part to a local shop and told them what the application was and they fixed me up with the Buna orings, so far working good. Thanks for all the input, I got a crash course on orings. (The oring that was in there was just rubber)
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
  13. #12
    Arizona
    William I don't know if he did not have Viton or if he thought Buna would be best but I wasn't about to grill him over a $1 sale and to boot the building is closed to the public due to Covid and I had to wait outside (110 degrees) while he took my part inside and fitted it up then brought it back out to me.
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
  14. Likes William McCormick liked this post
  15. #13
    Jul 2018
    Cumbria, UK
    Buna N (nitrile) should be ok with brake cleaner, but you'll soon find out Viton (FKM) would be "better" but it all depends on whats in your cleaner solvents.
    Neither is any good for Acetone unfortunately
Page generated in 1,713,286,237.46627 seconds with 18 queries
