Results 1 to 25 of 50
Thread: chump articulating LED light
    Aug 2016
    got this lamp thingy for free
    thought it could make a good welding light
    my welding table is small, no crowed table with this
    base
    close up
    Charl
    Mar 2005
    Under a Rock
    Re: chump articulating LED light
    yeah those work real good.
    I have a snap on light I use on the bench occasionally.
    especially helpful with tig...
    if you do any stick or flux core... keep the light at a safe distance.... don't ask..
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Mar 2005
    Under a Rock
    Hypertherm PM 45
    HTP 221
    Arizona
    My old eyes love lots of light too:
    Twelve bucks later and my LID is LIT!
  6. Likes ronsii, 12V71, whtbaron liked this post
  7. #6
    Cool Re: chump articulating LED light
    Very enlightening!!!!
  8. Likes 12V71, LtBadd liked this post
  9. #7
    I'm gonna have to look for a light like that, hopefully I don't wipe it off crawling through trailer frames.
  10. Likes ronsii liked this post
  11. #8
    That's the problem I had with anything on the 'helmet' half the time I'm under a rig there isn't enough room for even the hood thought about some of those sticky strips of bright leds... you know like the sell for headlight accents... of course then you'd have to put a battery holder somewhere on the hood too....
  12. Likes Lis2323 liked this post
  13. #9
    That’s a MAJOR prob with mine. Haven’t broken it off but it catches on **** and knocks it off my head.
    I originally wanted it mounted “chin” height on the helmet but couldn’t get the angle to be effective. Gonna work on a recessed flush mount rig.
  14. Likes 12V71 liked this post
  15. #10
    This would be better for crawling through trucks and equipment...
    Special Edition Covid Welding Mask
    Safe yet stylish. Wear it when going to the bank for a loan.
  16. Likes 12V71, ronsii liked this post
  17. #11
    Jun 2017
    AJO, ARIZONA
    That headlamp is a great idea!
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    RONALD REAGAN
  18. #12
    I once crawled in to the throat of a rock crusher with a #10 lens in a torch goggle... I was a reverse racoon for a week. That setup would have been perfect.
  20. #13
    I once crawled in to the throat of a rock crusher with a #10 lens in a torch goggle... .
    I assume you had your own padlock on the genset panel ????
  22. #14
    But of course. The gensets were off too. Saturday project.
  23. Likes ronsii, Lis2323 liked this post
  24. #15
    To add to the lock out/tag out question, I take that pretty seriously. I have a friend that has no legs from being wrapped up in an auger feeder in the early 80's when somebody pushed a remote start button. That company is no longer in business...
  25. Likes ronsii liked this post
  26. #16
    Sad. And so sorry to hear. Truth be told I get the shivers thinking about scenarios like that.
  27. Likes 12V71 liked this post
  28. #17
    Like Terry, those kind of thoughts give me the shivers!!!! was about a year or so ago a mill down south of us had a guy get pulled through the debarker cause he jumped in to clear something and someone else started things up without knowing he was in it he survived but there was massive damage and lacerations!!! don't know if he is still alive today but that kind of experience certainly won't make you live longer.
  29. Likes 12V71 liked this post
  30. #18
    It only takes a second either way. Even working on trucks I disconnect batteries before I work on belts and fans, etc. Saw a guy drop a 9/16" wrench on a starter once and almost catch the truck on fire.
  31. Likes whtbaron liked this post
  32. #19
    NW New Jersey
    Great Idea, I have a light magnifier on my bench, and it mounts on the edge of the bench. When not in use it always gets in the way. Need to make one of those.
    I've seen several wrenches accidentally turned into heating elements. Usually by loosening the hot lead on the battery first, nut breaks loose, wrench suddenly goes to ground and welds itself to frame. I guess thats why the manual usually says to remove the ground first.
    Lock Out /Tag Out - Not just electric. Hydraulic, Pnuematic , also. Most grinders and chippers have pins to hold the flywheels, even coasting unsecured they can cause some serious injuries.
    @ Lis2323 When I first saw the picture, I thought it was a hero cam.
    How long do you get with a set of batteries, is it rechargeable?
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
  33. #20
    The lamp has triple A’s if I recall which probably adds to the bulkiness.
    Now that I know it works well in theory I will need to search for a lower profile unit I can hopefully recess into the helmet
  34. #21
    This is how I mounted my magnifying light.
  35. Likes ronsii liked this post
  36. #22
    Or weld outside in the wind, rain, and bright sun with sweat drippin' off your nose. Outside rocks. Pantywaists!!
  37. #23
    You forgot brushing the snow off the welder panel to adjust the amperage.
  38. Likes ronsii liked this post
  39. #24
    May 2016
    Southern California
    Yup, welding in a snowstorm makes you appreciate leather jacket and gloves! crank up the amps!
    Miller Multimatic 220AC
    Miller Thunderbolt 225
    Victor OA
  40. #25
    Feb 2016
    Myrtle Beach
    I have been using this one for a while. It has a magnet on the bottom of the light and a little steel plate glued inside the helmet so you can easily take it on and off or use the magnet to mount it on a piece of steel. I also have a optrel weld cap that I use in tight spots.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
Page generated in 1,604,022,842.20244 seconds with 13 queries
