Results 1 to 6 of 6
Thread: Cold wire feeder
    Cold wire feeder
    Hello.
    I work 10 hours a day almost always on the same thing. All lap joints with long beads.
    Last month I had bursitis in my left arm and I had to stop production for 10 days.
    With the objective of relieving the tension in my left arm I am thinking of purchasing a cold wire feeder like CK WF3 or 5.
    My questions:
    1) I have been welding aluminum for three years and I can make good welds. Will a cold wire feeder keep the welds looking good?
    2) Can I expect greater productivity?
    Thank you all.
    Re: Cold wire feeder
    Forgot to say... I using TIG process.
    SoCal-LA
    Hmmm, that is a good question. I bought one years ago to drive specialty mig wires for tig. It did not have pulse mode like now. I guess if you could set the pulse precisely you could duplicate nice welds. However I would not like to be tethered to another machine on my wire feed hand. In the last few years I have only used it to dispense tiny mig wire that I feed manually anyway.
    I would consider bigger weld rod first, grabbing like 10 inches at a time, and feed until your fingers get too close. That might require reprogramming your tig welder. I like pedal pumping cosmetic beads, increasing the current into the root and cramming the rod to plump up the bead, then decrease the current to provide definition to the weld and slide into the root again. That does not work for aerospace work where a fixed current must be adhered to while feeding thinner rod and melting the puddle into the root. If you used a wire feeder to the process you have to document the wire size and feed rate. Best not admit to a wire feeder.
    MillerDynasty700DX,Dynasty350DX3ea,Dynasty200DX,Li ncolnSW2002ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig4ea,MigMax1ea.
    Thanks.
    Iím going to test a pulsed MIG today but I donít have much hope that a MIG will do a good finish like TIG.
  5. Likes driz liked this post
  6. #5
    Ceres, California
    Lincoln pulse on pulse aluminum is close.
    Available on the power mig 350 and all powerwave welders.
  7. #6
    Mar 2014
    Kevin Morin. Try searching his name. If you find it, PM him and you will be surprised. Knows more about it than anyone I know.
Page generated in 1,606,666,696.11132 seconds with 12 queries
