Results 1 to 25 of 25
Thread: New NOVA Wireless Pedal for Lincoln, Miller, ESAB, HTP, and Everlast
    Nov 2008
    The new NOVA wire pedal has just been announced. Delivery should be in September sometime. It could be sooner, but we don't want to press the final stage.
    Price is going to list around 299.00
    Let us know if we can save you one.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Feb 2016
    S. WI
    Re: New NOVA Wireless Pedal for Lincoln, Miller, ESAB, HTP, and Everlast
    What kind of power does it use? I would want to change it over to 220 that way you won't need another cord to drag around with the welder.
    Nov 2008
    120 for the dongle, and battery for the pedal. I am not 100% sure how the power would matter on this one. The rear connection would be eaten up (on our units) by the watercooler. How would you supply a low amp 240V voltage plug?
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Delaware
    Is Everlast going to be selling that pedal for all the listed welders? What about the AHP, Lotos, Eastwood, Primeweld, Razorweld, etc. ? Are they going to be programable so if you have 2 or 3 welders in the shop they will not interfere with each other?
    Nov 2008
    Right now these are for digitally controlled units. Will have to check on the future ones for non digitally controlled units.. The progammability issue is being resolved I think. I'll have to check. It will require a frequency switch, I am sure.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    S. WI
    I think it would be easy to tap off the power switch or from the cooler and mount another outlet on the back of the welder. There is no correct way to get 110 volt with out a neutral on 240 single phase. That's probably why the coolers are 220 also.
    Aug 2019
    northeastern PA.
    Mark, have you used one yet? I might be interested in one if I can get hold of some reviews.
    Nov 2008
    Still in final revision. Not yet used one.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    S. WI
    Got an ETA on these?
    Nov 2008
    Just ending the final phase of testing for distance/ interference etc. All tested concerns seem to be clear. Final preproduction samples are being made now. Hopefully we will have stock by end of year.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Aug 2019
    northeastern PA.
    are y'all lookin for testers?
    Nov 2008
    No, lol. We got plenty of those standing in line.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Jul 2020
    Is there going to be a pre-order opening anytime soon? Don't want to miss out lol.
    Nov 2008
    We'll let you know. Covid has made things unpredictable. Should be soon though.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Aug 2019
    northeastern PA.
    I have a 256 D....will the wireless pedal work?
    Nov 2008
    It should.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Apr 2020
    AntHome 92025
    It's been a while... any update on this?
    Millermatic 255
    Everlast Typhoon 330
    Ready Welder I
    Hypertherm 30XP
    Nov 2008
    Early April we hope. They are in production this month sometime.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Nov 2008
    The production models are scheduled to be available soon. BTW, the units are rechargeable and under our heavy testing last past 40 days between charges on a full 8 hour shift of constant 100% duty cycle use. Compared to similar models we tested, this is more than twice the life span. Expected recharge cycle life is 300 cycles before the batteries begin to decline. The unit also has an off switch to extend battery life when not in use.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    S. WI
    SO I finally got my pedal and tried it out for the first time tonight it will not vary the amperage just acts the same as a thumb button. Has anybody had a problem with there's? It was to late to call so I thought I would try here going to call in the AM I am using it on a 350EXT
    Nov 2008
    What do you have your machine set to on the panel? Is it 2T, pedal, 4T, 2T+Pedal, or 4T +Pedal?
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    S. WI
    It is on the same setting that I use the standard pedal on. There wasn't any paperwork in the packaging I assumed you used it on the same settings.
    Nov 2008
    Which is it on then? Need all the info you can give me.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    S. WI
    It is on pedal the same setting I use with the wired pedal
  25. #25
    Nov 2008
    Sounds good. Just call the guys over at ext 207 at 977 755 9353 and they can help you and get you another one if necessary.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
Page generated in 1,713,265,259.68934 seconds with 20 queries
