Results 1 to 6 of 6
Thread: 4-wire power to 3-wire receptacle
    Apr 2013
    Need to hookup an adapter for temporary jobsite power to Miller Dynasty 200DX. Available is 50-amp, 230-volt, 4-wire receptacle. Welder has 50-amp, 230-volt, 3-wire plug. Should the center pin of the adapter's 3-wire receptacle be connected to neutral (white) or ground (green) or both? Maybe a dumb question, but just want to be safe.
    Laredo, Tx
    Re: 4-wire power to 3-wire receptacle
    Quote Originally Posted by ezduzit View Post
    If you're talking about a 14-50R, then it should go to ground if that is what it is designated on the original plug. Neutral not needed unless you need 120V input power.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  3. Likes ezduzit liked this post
    Apr 2013
    Jobsite receptacle looks like this. Is wired single phase. Ground is outer housing.
    Jul 2011
    Ottawa, ON Canada
    OP, you are correct that the outside is the ground on that receptacle. I've attached a photo for reference.
    To go from the 50 amp 125/250 twist lock to your 6-50 receptacle you need, you'll connect the ground to ground. X and Y are your power terminals on the plug and receptacle. Ignore the W terminal, that is for the neutral which you won't need.
    I'd make a nice adapter cord, maybe 10' ling with 6awg cable with the right ends for the cable. Then you'll have one for future use. Or, with 10' of cord, you could just keep changing the male end to whatever plug you need. Either way, it's handy to have adapters for different receptacles.
    Sent from my new phone. Autocorrect may have changed stuff.
    If the women don't find you handsome, they should at least find you handy!
  6. Likes ezduzit liked this post
  7. #5
    One best ways is go to Home Depot and look best price in 50 amp.
    I typically use a range plug 4 wire 50 amp (2 wire hot {red & black} wired 1 ground{green} and 1 Natural {white}).
    I can use for everything.
    The 3 wire is 2 hot and ground good welders but if something needs neutral your out of luck.
  8. Likes ezduzit liked this post
  9. #6
    Apr 2013
    Thanks fellas. Got the job done after wiring it to ground.
  10. Likes Broccoli1 liked this post
Page generated in 1,603,646,240.82962 seconds with 13 queries
